F135 exhaust manifold problem
Seattle, WA
Hey, the counter weight on my exhaust manifold's heatriser is broken off and the stud that holds on the little sheild that protects the coil for the heatriser if broken off too. Is there anyway I can fix these or am I going to have to find a new exhaust manifold? Thanks. :D
This is for my 65 F motor by the way.
here is a pic of the weight I am talking about(old pic):
you could pull the manifold off and take out the heatriser valve..... it would stop the exhaust gas from hitting the intake manifold, the only bad thing is that it will take the motor longer to warm up when cold.
I think he said it has broken off since, Charlie.
I agree that the easiest solution is to weld the flap open (hot position) or remove it altogether and plug the holes. The parts are generally unavailable for replacement of the flapper, and while you might be able to drill out and replace that broken stud, it might be very difficult to find the right size.
On the other hand, someone here has a used exhaust manifold sitting around that works, I'm sure. CDan might have a NOS exhaust still, too.
"while you might be able to drill out and replace that broken stud, it might be very difficult to find the right size"
The manifold would have to be removed to have a chance at an accurate job of drilling out, but most auto parts stores are carrying metric studs these days and it won't be an unusually difficult to find thread.
Might be possible to use a flapper/weight from some other engine once the broken one is removed but there's little change without one except maybe in the cold parts of the country.
Yeah, no way I would attempt it without removing the manifold from the head. As far as the flapper, I have yet to find an exhaust (multiple tries) manifold where the flapper wasn't fused to the rod. So, getting one off of somebody else's might be problematic.
PS, whatever you do, don't throw away the bimetalic spring if you have it. They aren't easy to find. And if it needs a home..... :grinpimp:
Thanks for the advice. The little spring is still on there too. I will see what I can do with finding a replacement. If not then I guess I can just weld the flapper shut. :doh:
Well, I guess SOR still has the little sheild studs avaliable. Now all I need to find is the counter weight. :D
Edit: I have a line on a 73 manifold. I know that this wont work for me but I think the heatriser parts are the same( according to the SOR site). If this is the case, IDave you can have one of the little springy deals. :)
I'm pretty sure the parts are the same on the two different exhaust manifolds as well. I haven't taken a ruler to them, but they look the same on my rigs.
I've never measured them side by side, but visually, they look the same to me too.
Whenever I have a manifold off the truck, I take the opportunity to remove the butterfly from the shaft. Never did like OR TRUST those flappers. ;p
Of course, living in Southern California, you never had an opportunity to see if it worked, anyway! ;)
I can tell you from personal experience that they do make a difference when it is 20 degrees F or below. :D
