Anyone have any luck finding an F-Type Siamese port header? Original manifold ports are worn too much. Thanks.
The ports are completely eroded away. Only reason I would want a header is the ease of replacement.What do you mean by “worn” ports?
These engines don’t exactly need headers at the low RPM’s they run at. You may be better off sourcing a good used exhaust manifold if needed.
I am unaware of any sleeve for this manifold. Looks like a standard exhaust manifold, intake bolts to a heat riser portion and they bolt onto the head. I can add a photo of that would help.There is a sleeve that slides into the manifold as well as the head ... is that the part that is bad? Or the actual manifold?
They have not made the header for one of them in a LONG time
Maybe mark aka @65swb45 has a used set of headers? Used is your only option most likely
Clifford’s may be able to make something for you... but... it will be costly
How much do you want for it?I do happen to have a header for the F135.
Definitely interested in this. Can you message me with what you would want for it?I have no idea of what it is worth. Bought and later sold a FJ45LV project before joining Mud in 2005. It had this header on it I picked up a stock exhaust manifold and switched out before selling it. Has carbon inside but the flange piece used to weld to the exhaust is still virgin. Figure the engine was started but vehicle was never driven. Can see light surface rust where paint chipped off but where is was bolted to the head is still shinny metal. Stored inside all the time I had it. Here are a few pictures.
View attachment 2012858View attachment 2012859View attachment 2012860
