SOLD F engine heater water pipe
Status
Not open for further replies.
Camarillo, CA
I'm looking for a heater water pipe for my 1974 FJ40. This is the metal pipe that bolts to the right side of the block in between the lower radiator hose and the heater control valve at the firewall. It is circled on the attached diagram.
Thanks,
Ray
I have this pipe…and I will be in Ventura on Friday.😊
Great, thanks Mark. Let me know how much, and I can meet you as you pass by Camarillo if that works for you.
Ray
I’ll be going out the 118. Will pass by the Somis turnoff around 11am. $50 for the pipe.
Mark, I can meet you in Somis at/around 11:00 on Friday. My cell phone number is 805-491-3062.
Matt, thank you for showing me that you have the one I need. Do you have that posted on your VintgageTeqParts site? I didn't see it.
Ray
Looks like I have a whole bunch of 2F oil cooler pipes that I forgot about too. D’oh.
I will plan to meet you at the produce stand just east of the 3 way. Don’t know if there is cell there.
Mark, I just called and left a phone message, but I'm actually closer to Moorpark than Somis. I assume that you will get off the 118 freeway at the LA Ave. offramp at Moopark where it turns into the 23 South. If so, we can meet at the McDonald's at what time you choose.
Thanks,
Ray 805-491-3062
Let’s aim for 10:45 then.
Your should mark your thread sold. 😉
Hello Mark,
I'm local (Camarillo) and you've done work on my 1974 FJ40 and I've bought parts from you over the years.
I now have a 1978 FJ40 that I'm de-smogging and instead of de-smogging the original stock carb, I wanted to go to the non-USA Aisan 21100-61012 carb. Do you have any of these? Also, are there any modifications to make to these or not? If so, can I send the new one I purchase to you for the modifications?
Thanks,
Ray
Hello Mark,
Hello Mark,
Thanks,
Ray
You would have better luck to contact Mark at his shop. His numbers on his tagline.
Hello Mark,
Thanks,
Ray
Returned your voicemail.😊
Status
