- Thread starter
- #241
try driving slower...
That works. If I slow down to 90 the BJ74 gets *way* better mileage than the HJD81. At 120 it only does a bit better.
i have found since i moved down here my mileage is WAY better than it was in Alberta.
less head winds.
less hills
slower moving traffic.
so... you are selling the HZJ81 then?
so after everything I assisted with in that truck - roll cage, new rear doors, getting that mofo heavy tent on top and off again.....you know you need to put the passenger seat back in, right?
Welcome Aboard Phillipa (and the 'Mud salute)No progress to report. I'm busy buying and selling houses. Hopefully the one we end up with will have a garage (and no pink shag rug) and I can trade in the air nailer for the impact.
If I hammer it the boost will run to 19PSI. On normal highway running(120KPH) the boost will run at about 15PSi and EGTs 1100F. With the same fuel and the wastegate connected it'll stay at 8PSi and go over 1400F untill I take my foot out of it.
I put together an intercooler for the prototype of this rig but haven't bothered using it. The exhaust of 2.5" open with a couple bends to keep the noise tolerable.
Update on the wheels. I got the axle together and tried a wheel on only to find the that front part of the luke arms (where the drag link connects) hits the tire. I need about 1/2" less BS. I pondered cutting and welding the arm but quickly decided that I didn't have access to a welder that I'd put up to that. I've been using a Miller 135 that is fine for the little stuff. In the end I ordered up a SKY mfg wide track kit and picked up some IFS hubs at the wrecker. I'll match it with some wheel spacers on the back for now and might try to widetrack the back using ifs hubs later in conjuction with a disc brake conversion.
Brad I think the FJC wheels are about an inch narrow. You can see a bit of crown in the tread. I'm going to run them anyway and will know after I put 10,000kms on in July whether it was a bad plan or not. I think I remember a vender that takes aluminum rims and machines them for a beadlock. I should look into that.
Sky's Off-road Design - Home
Do you have a write up of the air converted e-locker? Built looks great!!
I'm beginning to think that it will go to the States next May when it is 25 years old.
