I checked the cover area for gouge, crack, dirt, before putting on the OEM Toyota gasket along with all Toyota parts in the rebuild. Checked the surface for warp and it doesn't look it. No crack in the housing. Weird thing is it's fine since engine rebuild 5k miles ago and this leak is only last 1k miles, that's why I removed the heat shield to be sure. I cleaned it real good with brake cleaner, Simple green this morning and seems it must be leaking a lotwithin 7 miles driving today.
I"ll pull the gasket again this weekend and get new gasket to reinstall with a bead of sealant on top of the gasket to build up extra compression in that area. Any reason why it would leak thou? I hate to be doing this 2nd time and still leak. TIA.
