everything needed for disc brakes 1981 47 series
Queensland, Australia
from what i have found its just knuckles from a 60 i have lined up for free (win), a 80 series booster and late master from mr LC then just i just got to change the length of the push rod, also am getting full hub and bearing kits front and rear well im at it, just making sure there isn't any odd thing im missing that will hold me up, cheers.
I'm thinking you need:
knuckles, hubs, rotors, calipers and as stated maybe hoses
you can use your existing master just by removing the residual valve from the front circuit
Yha mate, will have the knuckles with everything on them ready to go, the calipers are good but no big deal if i need new ones same for pads and roters, as for the master its only a few hundred and i know it will work all good and probably needs replacing anyways, i wont worry about the hoses i can easily get others if needed from every video and other post on it i haven't seen anyone talk about the hoses being different so im not stressed
If your swapping out knuckles you should probably center them per the fsm using the centering tool.
Read here:
