Ethanol 2F?
"the whale's vagina", CA
So, saw a 60 minutes episode the other night talking about Ethanol as a future fuel. They mentioned briefly that existing cars can be converted to use the Ethanol fuel. I was curious about this as I have just acquired a 70 FJ55 I will be doing a restoration on, that will take around 3 years to complete. By then I would guess that this alternative fuel may be available readily in my area. Does anyone have any ideas on what it would take to convert a 2F to use Ethanol? Not sure I will go this route just more interested in what needs to be done to an engine to make it run off of Ethanol? Even better/cooler would be for it to be able to run off either Ethanol or Gasoline, just like the "flex" cars they are making in Brazil now. Any technical info/expertise appreciated.
Thanks,
Noah
E100, pure ethanol, is not yet commercially available, though a lot of people are homebrewing. To run E100 you'll need to advance your timing a bit and maybe change carb jets. Otherwise it should go.
Ethanol blends are in use already. The 89 and 92 octane fuel in this area is 87 octane regular blended with ethanol to increase octane (E100 is 113 octane). Most blends can be run without changing anything.
Doesn't ethanol, especially in high concentrations, destroy some rubber (fuel lines, carb gaskets etc.). Unless that's only methanol that does it..... Otherwise you would need to replace a lot of hoses and carb parts I think.
To run the E85 that is currently available at gas stations in the USA, a gas car will need bigger carb jets and advanced ignition timing.
BUT, what is needed to get any efficiency from alcohol fuel is compression, and lots of it. Modern FFV's only see a 10-20% drop in fuel economy w/ alcohol because they have high compression, efficient engines.
An FJ55 is gonna be a pig :) running on alcohol.
I was reading about this earlier today. We have had a few customers emailing us asking about converting their BMW's to run on e85. Ethanol fuel is higher octane but it burns differently. It's also supposed to be highly corrosive. Apparently the flex fuel vehicles that can run e85 have different injectors, fuel pumps, and lines than the regular models. And then the knock sensor is set up to change the timing dramatically as needed. I wouldn't think it would be worth the trouble on an older vehicle. Once the carb jets were changed, and the timing was set, it would work, but you get less power and gas mileage actually goes down from what i've read. It's cheaper, but if you get less power, and the mileage drops, outside of the environmental benefits, why bother?
Efficiency of an engine is directly proportional to compression, IIRC from physics 101. E100 is 113 octane. Some racer should be able to chime in here, but you should be able to easily run 13:1 compression with 113 octane. That will allow you to run a pretty radical cam and recover any lost power.
The increased power and enviro benefits may outweigh the lower mileage for some people, especially if you live on a sugar cane plantation and you have a decent still.
http://www.google.com/search?hl=en&q=ethanol+from+sugar+cane
Worth it..
I think that we hard numbers on conversion cost. Be it SBC or F2 the money is really where it starts... (Not that, that is all there is to it but, that is what it takes to make people move off gas.) Otherwise we really don't know if it is affordable.. or "worth it".
I did a little math. In a perfect world where you can buy whatever you want at the corner.
The chart from excel is below. Basically, decide if I drove 100000 miles what would I pay in my cruiser. (Assuming I get 17 miles per gallon.... I know I know... More like 10)
Gas at this weeks national price would cost $17382.35
Propane which I weight to get less MPG by 10 % was $11129.41
Ethanol was with the same loss in in MPG as propane $17470.58
Desiel with a added MPG rating of 10% (because Deisels generally get better MPG) was $15337.05
G-17382.35
P-11129.41
E-17470.58
D-15337.05
Propane seems to be a far and away the best. So much that I check the numbers again.
Even in the highest price place I coudl find data for (NY state) it was 222 a gallon.
Which made it 14364.70
Still the cheapest..
A propane kit for SBC (TBI 350) is 1420.. I have not heard the cost of enabling the same engine to be E85 capable. (Which is the manu.'s are setting up for.)
I will be doing the propane kit... It should save me. 1500 over the next 100000 miles after I pay for the conversion. (Right! like I am going to drive my 35 year old beast that far.) It will probably end up costing me money.
What did I learn.... If you are doing alternative fuel, it is likely that you are not doing it for money.
Here is a fact that I can prove but, refuse to put more time into. People who sell oil have done a great deal more math than me and are a whole lot better at it. They have figured out the exact cent that we are willing pay. They know any more than that we (and the market...) will move on to something else.
I have been taught since a child that my oil "dependency" is to great. I need to be prepared to deal with a world where oil is not available. I have also been taught the environmentally destructive nature of standard gasoline emissions is proven and irresponible.
I am not a liberal democratic or conservative republican... So I am not making a statement here. Rigs should be capable of running in the rough on fuels that are capable or delivering a good time. A less expensive time is a better time.
I hate that oil corporations have me by the ....... I am doing it out of spite.
like the calculations, but you left out an important piece-
each of those fuels will provide different mileage because of the different energy values of each fuel. you will get better mileage out of a diesel than gas than propane, and i would guess alcohol would get you somewhere between gas and diesel if you get the compression right.
if you could figure that out, i would guess you would find diesel to be significantly better than you found on your first round of calculations!
Minni pig is running this fuel now in his 55 check it out in 55 forum .
I run anywhere from E50 to E90.
Downsides:
1) When I run a higher percentage of ethanol. like above 60%, and its colder then heck outside, the pig doesnt like to start and I have to allow it to fully warm up before leaving.
2) If your vehicle is not set up to run higher then E15 then you can have issues with fuel system failure. Rubber, plastics, o-rings, FI systems, ECU's....etc.... I have all paper gaskets in my carb and replaced some rubber lines. Havent had any issues yet.
3) Will need to adjust the carb or jet it for more fuel delivery. And if you jet it you're stuck using a higher percentage of ethanol as it will deliver more fuel . If you put in regular gas then you're sucking.
4) If you dont jet or adjust carb you might experience idling issues and engine might or will continually die when coming to a stop or slowing down to fast due to fuel delivery.
Upsides:
1) I did a simple adjustment to the carb and then use my choke to adjust mixture depending on what percentage im using.
2) I spend about 1.40ish per gallon of E100. Its like 117 octane... I mix my own fuel blends and at times I put in a gallon or two of diesel.
3) Yes you can make your own if you like and save money.
4) The pig does run a hell of a lot cleaner. And the engine seems to enjoy running a decent E40-E60 blend. I run higher when on longer trips.
5) E85 is cheaper then regular gas and you can mist at the station if needed. Here it runs between 1.85-2.10 per gallon.
6) I dont have a nasty exhaust smell as the ethanol burns cleaner.
Im sure there is more... but thats the nasty in a nutshell. I enoy mixing my own fuel and really enjoy running ethanol.
And I also love B100 and blending it. When I have the space and time I intend to make my own E100 and B100 fuels.
The energy content of ethanol is 30% lower than gasoline on a gallon per gallon basis. Therefore the mileage is at least 30% lower for ethanol.
Diesel has an energy content 17% higher than gasoline, and diesel engines have a higher thermal and volumetric efficiency.
Ethanol is not corrosive but it does absorb water, which is mildly corrosive.
I need to jump in here - you do need a higher volume of ethanol, but with that volume you can run more advanced timing and greater compression. Ethanol blends will also run cooler. So in theory, a E85 vehicle would need a bigger tank, but a smaller radiator and engine.
I do not think you can successfully run E100. Some drag racers I know have developed their engines on E98. They claim you need a little top end lube as the ethanol is very dry.
I think you could probably get somewhere running a MegaSquirt computer on a 3FE. That is probably the closest a 40/55/60 series can get to being a Flex Fuel vehicle. The megasquirt can take the addition of a fuel composition sensor (found on newer GM vehicles) which will monitor fuel coming out of the tank and allow the computer to prepare accordingly. I think the megasquirt requires that you change the air door from Toyota with a GM style air sensor (MAP or MAF - not sure). But the 3FE is still w/o knock sensor or adjustable timing. These could probably be added, but we are talking about a tractor engine here...
Downsides:
Upsides:
How is the power output when you are burning the corn juice?
I can tell a difference. On the highway in 4th gear it accelerates much better when I floor it. Thats using a higher percentage of ethanol. Seems to have more power in the city too. I havent noticed any difference in my fuel economy and I recently went down to Greeley and used over a 90% blend of ethanol. Drove great on the highway but as soon as I had to stop the choke came out to keep a good air/fuel mixture. The ole 2F didnt miss a beat all the way down. Engine also runs smoother and no nasty exhaust smell. So far I have been very satisfied with blending my own. When we get more fueling stations that offer E85 then I will rejet. Until then I just pull out the choke.
I am lucky in that I have a fuel transfer station near my home. So I can buy 55 gallons for 1.40 per gallon of E100.
