- Thread starter
- #181
Bogo,
Very informative and technical- I like it! How about a "how to" or some pictures from your lab on these shields?
I understand all that and I understand the magnetic strip is not involved in this at all. I've made my own low frequency passive RFID tag readers from TI modules*. When I tested out how to block them, I found out that it was much more effective to keep the RFID tag in the "dark" so it never powered up. To do that I found out I had to magnetically shield it. A well formed aluminum foil shield could keep the tag's transmissions from being read, but it couldn't stop it from powering up. Cut a small hole in that foil shield and I could read the tag. Sure the read distance was lowered, but it was still readable. When I tried the two transformer plates, I stopped being able to read the tag. When I stuck a small antenna loop from a RFID reader set to passive mode in the sandwich I couldn't get a read when the other reader was trying to read it. The nice thing about the transformer plates is I didn't need them to have 100% coverage like the aluminum foil needed. They only needed to cover a slightly larger area than where the antenna on the card was.
* 10 years ago cattle RFID tag readers were $1,500 minimum for a dumb one with no display. TI RFID modules from DigiKey could be had for $75 each. All you needed to add to the module was a serial port level translator chip, antenna, and power supply. Then a PDA with a custom application on it could talk to it.
BTW, many car keys now have RFID tags in them.
