Engine
Mpls
1977 FJ40 engine bay very warm after driving? All fluids normal. No leaks. Do these vehicles normally run hot?
Any input appreciated.
Thanks
Does your rig have the 2F or did someone drop in a V8. You can use one of those infared laser thermometers to figure out how hot it's getting.
I haven't done a coolant passage flush yet, but there are a few how-to threads if you end up wanting to try that. "Mark W" has posted a few tips on that. I also recall "steamer" posting how he did his flush.
Does it have headers instead of the stock cast-iron exhaust manifold? Headers will radiate quite a bit more heat into the engine bay and firewall.
Also, check the vacuum advance mechanism on the distributor if you have one; these can rust up over time and if you are not getting enough timing advance it will run hotter on the highway. Check your base ignition timing while you're at it.
No headers. New GM distributor.
Fair enough. Take some time to research the principles.
Timing has a direct correlation to engine temperature.
I have headers... I know you said you don’t... but, my headers run at ~450*, using an infrared thermometer.
So, I suspect the engine bay is also very hot, with an exhaust manifold... especially, on hot, sunny days.
Even with the headers at 450* and hell-like heat, emanating thru the firewall, my temp gauge reads about 5/8ths. So, the heat is air temp, under the hood, not coolant temp.
If your gauge indicates the engine is running hot, as @65swb45 said, improper timing can cause engine temp problems. Make sure you timing is correctly set... you valves are properly adjusted and you spark plugs are good and are properly gapped.
Also, your coolant system could have air in it... it never hurts to burp your coolant system.
If your temp gauge indicates proper engine temp, the heat under the hood is part of owning one of these beauties!!
But, proper preventative maintenance also comes with them.
I always wondered why that is ? Logic would tell you as long as it is smooth running, what is creating the heat. ?
Completely agree. Dash gauges all run normal.
Temp gauge is normal.
