Your cats are likely old and somewhat clogged—which can back up heat into the engine. When I deleted mine.....10deg drop in temps next day. Funny enough I was running at 194 on flats on hot days.......and would climb from there. when I cut open the cats to confirm.....they were indeed semi clogged /still passing smog/ but likely backing heat up into the head/engine. If your cats are new or recently replaced I’d move to the next piece of the puzzle.
Remember the cooling (or cooking) system is the sum of all parts. With so many pieces in that system.....if one or two isn’t functioning optimally- then you are adding one or two deg.each and real fast u can jump 10. One or two degrees each below would be a 9-18deg.. bump—>
Rad cooling fins- cleanout and bend open shut fins
Rad felt surrounds-
Splash guard installed?
Thermostat-
Cats
Fan clutch
Coolant water ratio (increase water to 60/40 or more.
Winch or other obstruction
Larger tires/lugging engine
A lot of people focus on the band aid fix all of the fan clutch but everything needs to be on top top shape which is why when Robbie does hg’s he insists on a complete cooling system overhaul for warrantee purposes of a new hg.
Things like running larger tires or obstruction s of a winch can be overcome via fan clutch bump or hood washer mod. Etc... as a compensatory method.....but you really can’t have too many pieces of the puzzle functioning at a deficit before you start to see noticeable temps rise.
Rad felt surrounds-
Thermostat-
Cats
Fan clutch
