EXACTLY! To bad you bought a way over priced fan clutch.Sounds like I need to relax. Now that I can see actual temp numbers it's all I want to look at.
How did you arrange the O2 sensors. Any CEL’s? I don’t really think my cat is blocked at all but I’m now living outside the state of confusion known as CA and am already thinking about desmogging just because I can.no way to know really. I did notice my smog numbers were getting worse year after year....Until my last reading the smog dewd said - u barely passed. It was at that point i knew I was going to chop em off and inspect. I still think I ran a year before doing it......but at that point my temps were 199-200 around town and mountain passes were getting real annoying even with an Aux fan.
A partially clogged cat will cause poorer fuel economy than we already get, poorer acceleration, more heat build up under the front passenger area.How can you know for sure that the cats are clogged and is there any PM you can do keep them unclogged?
I know others have relocated the sensors to the pair port location but I’m surprised that spot is not too hot for the sensor.I originally chopped the cats and left the o2s in orig. 94 pre cat location. Running Cat less.
Eventually I bumped them up to the exhaust manifold (when I deleted the egr system) ports just to get them away from rocks down low.
no cels on a 94. In either location.
When my jeep or 80 gets hot I simply park it and drink a beer or two. $250 buys 12.5 cases of miller light.EXACTLY! To bad you bought a way over priced fan clutch.
