You can use it in a gas engine. It has added zinc. Your engine will appreciate it.Everywhere I look for Shell Rotella 15w-40 it is described as "heavy duty diesel engine oil". Is this the stuff or is there a gas engine version I need to find?
Yes, awhile ago Shell dropped the API SM/SN (spark engine) designation from the Rotella line except T6 5w-30. The oil stayed the same and everybody is still using it. It is high in zinc and phosphorous. Zinc is good for all engines and phosphorous is good for diesels. The API has placed a limit on the amount of phosphorous that S_ oils can contain because it might damage some catalytic converters, so Shell has had to drop the S_ designation.You can use it in a gas engine. It has added zinc. Your engine will appreciate it.
Good to know that a brand new bottom end is available. What is the advantage of using this and swapping my rebuilt top end vs paying $4,000.00 to CruiserParts for a complete reman motor ?11400-66041 Genuine Toyota Short Block Assembly
ToyotaPartsDeal.com offers the great deal for genuine Toyota parts 11400-66041 (1140066041) Short Block Assembly. All parts are backed by the Toyota's warranty.www.toyotapartsdeal.com
Rebuild your head. Swap all other parts over to it. View attachment 2155096
Because it's CruiserParts. Do a search for reviews on that business.Good to know that a brand new bottom end is available. What is the advantage of using this and swapping my rebuilt top end vs paying $4,000.00 to CruiserParts for a complete reman motor ?
I'm deciding between purchasing complete rebuild and having motor shop transplant. I thought that would be better option than having the shop do the rebuild since this is an older model motor.
Just trying to determine the best option for cost and quality ....... (self repair is not an option for me due to time)
), but they may drop ship it free to your local shop of choice . . .Because it's CruiserParts. Do a search for reviews on that business.
If you want to do this once and right, get a short block built by Mr Yota, the head refurbed by someone compentent and know that it's done the right way.Good to know that a brand new bottom end is available. What is the advantage of using this and swapping my rebuilt top end vs paying $4,000.00 to CruiserParts for a complete reman motor ?
Good insight.none of the online parts dealers will ship the short block due to weight (don't ask me how I know) - you will have to get it from your local dealer, and they tend to charge a bit more, unfortunately (> $4000 in my case
