So i noticed after i installed 285/75 16 tires the engine seems a little louder when accelerating. Is this normal based on the increased tire weight?
Must explainIt isn't really engine noise, it is the unconscious motor noises that you are making, because of the additional testosterone released by the taller tires.
That would explain the excess hair growth.It isn't really engine noise, it is the unconscious motor noises that you are making, because of the additional testosterone released by the taller tires.
I was thinking along those lines as well. My larger tires are surprisingly quieter than the old smaller set.Actually I had the same issue. Whenever I would put load on the engine it was louder after larger tires installed. My thought is the engine is working harder to push the bigger tire with no change in gear ratio.
