Engine Issues FJ45
Pendleton Oregon
Website
www.oregongrain.com
I got the 45 back on the road today :cool:, but I have an issue appear about an hour into the test drive.
1975 2F
F intake and exhaust manifold
1972 Carbuetor
While driving at a sustained speed 40 mph the engine bogged down and backfired a bit. I stepped on the gas and it bogged down even more. So I pulled over and let it idle for a minute, then headed out again..after about 500 yards it started again. It did this the rest of the way home. It is even worse on hillclimbs..
caveat: it ran great from cold to about an hour then started doing the above symptoms.
Any thoughts. I will look in search for obvious points, but do not know exactly where to start.
Here is a pic of the carb with gas level. It is low? Could this be it? Do I need to adjust the float level possibly?
How old is the fuel ?
How long ago since you went thru the carb for small stuff possibly in the jets ?
You might raise the float level a little bit, better have someone else with more knowledge chime in on that also.
It will run w/ the float level set that low.
But the description of the symptom sounds like a carb that is starving for fuel. IOW, it has enough fuel in the bowl to start running (as pictured). But after driving for a few seconds or minutes, fuel is no longer getting to the carb in sufficient quantity.
I would start by changing the filter and doing a delivery volume test at the carb fuel line.
If problem persists, do a vacuum and pressure test on the fuel pump. If that's OK, then remove gas cap and blow back through fuel feed to dislodge the rust on the tank pickup.
Timing at idle, but what about advance? Mech or vac? Not to be dumbass, I have only owned 79 and later models....
Thanks for the tip..
Todd, if the truck ran fine for the first hour, and will run again ok for the first hour, then I would suspect that vacuum pressure is building up in the fuel tank, fighting the fuel pump to deliver the fuel.
Running the float that low WILL exacerbate diagnosing the problem. Not saying I haven't run rigs set like that, but it won't help you while you're trying to pinpoint the problem.
Bull;
According to the BOOK [No. 98154], ur not getting the right fuel flow. Like FJ40Jim said, check the fuel filter and mechanical fuel pump; this has happened to me. Finally got smart and bought a new fuel pump (and filter) and got the sight bowel the mid level, where its suppose to be.
Thanks Mark. I will try that tomorrow. I have one of those old OEM locking gas caps that I didn't think sealed that tight, but you never know..
I also forgot to mention that this started after a 500 mile trip at freeway speeds.
Do you think I could have worked over the pump at the sustained higher RPMs?
Well, THERE"S your problem! In your first post you said this happened after an hour of driving. Now you say after 500 miles.
Trying to drive 500 miles in an hour is more than ANY LC fuel pump can handle. Elementary, Holmes!;p
Nothing happened to my 10 year old fuel pump after my 3600 mile roadtrip [with several 16 hour marathon freeway intervals] last month, so I kind of doubt that it's that.
So the prognosis has worsened now. It happens within 300 yards of the house. I replaced the fuel filter with a new one and cleaned out the metal hard line. Same issues.
I took the line off the carb and cranked it over; the fuel came out pretty good but I'm not sure to measure it by just looking at it. I put my thumb over the end of the metal line while it was cranking and no fuel blew by my thumb.
Another thing I tried once it died on the road was to pull the coil wire and turn it over until the fuel bowl filled up (which was slooow). Should a an empty fuel bowl fill up quickly?
Thanks for your help.
I'm guessing its the pump, but want a second opinion.
Yes. I don't think I could hold back my fuel flow with a thumb over the line. The pump is pretty simple to remove and diagnose--it's basically a big lever-operated diaphragm with a spring to push it back.
Perhaps it's the pump. That would be my best guess. But it could be blockage in the tank pick-up, or between the tank and the pump, or between the pump and the carb (though not likely), or even in the carb itself. Or extreme tank vacuum (how's your evap emissions system?). I'd still check the pump first.
Posting a solution for people who search on this topic at a later date.
I replaced the fuel pump, After I removed the pump I noticed the return spring had fallen off and was resting inside the lever. New pump on and had the same problem. Grrr...
So with a new filter and pump still having the same problem. Last ditch effort was to pop off the fuel line and use compressed air to blow back into the tank.
Viola problem fixed for 40 miles then symptoms returned...alas I had s*** in my tank clogging the fuel pick up.
I drained the fuel tank and rinsed it out. Out came long stringy light green pieces of rubberish plastic material. My best guess is that sometime a PO tried siphoning gas out of the tank with a garden hose and while removing the hose shaved little pieces off that fell back into the tank.
Once I had removed the particles I drove the 45 about 20 miles with zero issues. Hopefully this is closed.
Viva LPB~
Nice solution. At least you know.
I've had the spring pop off mine before, too, BTW. It can't be uncommon.
