FJ40Jim said:FYI, the cam turns 1/2 crank speed, so 1000RPM camshaft speed is 2000 crank speed.
woops
bsevans said:I'm a little confused. Didn't you already clean out the tank and blow out the fuel lines. When you blew out the fuel lines, did you see any rust come out? If so, I would replace the fuel lines. Also, when you cleaned the tank, were there signs of rust inside the tank. If so, I would line the tank with a tank liner like you can get from POR-15. I would be inclined to ask what type of fuel filter you are using and do you get any material caught in the screen after cleaning the upstream components. When this happened to me it was the filter (brand new, I might add). I went to a filter that had a larger area of filtration and the problem disappeared.
honk said:I know that you've said that you changed all of the fuel lines; did those include the rubber or cloth/rubber lines at the tank that drop through the floor? Rubber line can degrade inside and create a diode or one-way valve effect that's intermittent. Little flap of rubber closes off a line when it's sucked up by the pump and the line still seems clear when blown through.
There isn't a sleeve filter on the outlet hose inside the tank, I hope. Those things play hell.
One other little thing to try: change the condensor in the distributor. They can make you crazy thinking that you have fuel problems.
Mr. Toad said:Yes. Vapor lock occurs when a fuel line heats up. Ordinarily, vapor lock occurs in the lower-pressure fuel components. For instance, your stock fuel pump "sucks" from the fuel tank. Thus the line from the tank to the pump is very low pressure. If it were to heat up, then the heat--in combination with the low pressure--could boil the fuel and render the pump inop (because it can't pump gasses very well) and block the line because of the expanding vapor bubble.
Is there anything that could be heating it up so much down there? Your exhaust stuff should be on the other side.
Mr. Toad said:What happened when the carb was swapped?
IDave said:The fuel pump is supposed to deliver 2.22 US quarts (2100 cc s) per minute at 1000 RPM of the camshaft. (Remember, the camshaft turns 2x for every turn of the crankshaft, so that would be 500 RPM on the crank.)
cruiserbrett said:Camshaft turns 1/2 as fast as the crank, so 1000 camshaft rpm would be 2000 crankshaft rpm.
