I have a 77 FJ40 with stock 2F with about 170k miles or more. The engine runs fine, starts right up. Lately, I noticed I burn a lot of oil (approx. 1 quart 80 miles or so). I have no leaks. I notice especially when I coast downhill in gear I smoke excessively. I have changed the pcv valve but that did not do anything. I took it to Torfab to get other things like power steering but had them check the engine out. Compression test read 165-170 in all cylinders. Had them take the head off and inspect it, they poured oil in the cylinders and it past through in 5 mins so they said the rings are toast. Anyways, the cost to rebuild is $6500 plus $250 for shipping it to CA and $1500 for labor. So it will be $8250 before tax. This is a curve ball to me since I thought I may need a head gasket replacement with valve job etc.. What do you guys think I should do?
