My 40 shuts off(motor stops but maintains power to all electrical stuff) when I intro an additional electrical load. Usually on the highway using turn signal. So I finally figured out I could knock it out of gear, turn the ignition key off and then back to the on position, drop her in fourth, pop the clutch and cruise on down the road. Now (I assume this is related) when I attempt a cold start, she'll fire off them immediatelly shut off. I noticed I could keep it running by keeping the starter turning. After a bunch of short starting and cutting off burst, she continued to run finnally. Its like she gets warmed up a little and then runs. I replaced the coil(ignorance is bliss and expensive)to no avail.******A little background:3/79 fj40 w/apparently all OEM uder the hood 2F, (oh yeah, new owner of this fj since Jan.) few months ago i replaced plugs, plug wires, dist. cap, rotor. Set timing according to the Haynes manual and idle adjustments.(Problem has existed prior to these changes.)---Took ignition key set apart, seems to be fine.
Thanks for any advice!
