Electrical dilemma
That's basically what I just said in other words. A multimeter will read voltage but not test the cells. You can still have 12+vdc with a dead cell
Voltage measured across the battery is the total of 6 cells. Put a load on the cells, which is why we keep saying measure WHILE cranking and you have a true indication of the 6 series cells' performance.
You can NOT have 12V with a dead cell while UNDER load (cranking)...
So, a multimeter measuring volts is a GOOD test when connected right at the battery terminals and monitored WHILE CRANKING.
cheers,
george.
Does the ring around the ignition switch turn all the way off after you take the key out and close the doors? I forget if '95-up have the wee control module for that. There is a protection diode in it that goes bad, turns into a resistor. You just clip it right off the board. Little green box in the right hand kick panel, above where the locker ecu would be.
Ignition dimming relay
cheers,
george.
After checking Gils truck a few times, I am pretty sure it's not the battery. Dropping to 10V-11V range is normal for cranking. You have the juice, it is just not reaching the starter. Since it starts when you jump a wire to the starter directly means it's not the starter. So, you have either the main positive cable to the starter that needs to be replaced or the NSS.
Some of us think these symptoms point to a bad battery, but if your feel you're on top of it then go for it. Nothing like seeing first hand what's under the hood. Let us know what you find the problem to be.
I actually got the battery from 2KRacing, and discussed this issue with him. He is going to swap out the battery for another one, and add on a new ground and power cable from the starter to the new battery. So that will rule out the battery issue as well as the connection between battery and starter. Hope that fixes it.
It was mentioned that the problem began when the starter was replaced - this is important. I've never replaced the starter on my 80 - is the solenoid integrated, like a GM? It appears to be, based on the FSM, but that might be the rum talking... (it is Saturday night, after all...)
I've definitely had problems with the solenoids on reman starters before.
Unbolt the starter, but leave the electrical connections attached. Use a jumper cable to ground the housing to the frame. Turn the key and see if the starter spins. Do this many, many times. (yeah, just like that. Mmmm...) If the starter fails to spin at any time that you turn the key, then the starter itself is suspect.
I thought about that too and mentioned to Gil. We will be checking that as well when running the new wires.
If you do this, beware the starter spinning up will want to flop all over the floor, or in the engine bay, possibly damaging things. Clamp it to something heavy please.
I hope you find the source of this problem soon @Dr Gil . Please let us know what fixed it. I want to learn about what might happen to mine some day.
As mentioned above, if nothing worked until you jumped it with another vehicle it may in fact be a bad battery, had it happen more than a few times working on other peoples rigs. Batteries can show decent voltage but have next to no amperage output which makes the job of starting a real PITA. My brother and I owned and operated a small shop together and we saw several of these cases. Swap a known good battery of the correct cold cranking amps into it and see where you are. As for a power drain in the dome circuit, if it's killing your battery that's one hell of a drain or one poor quality battery. Since the dome circuit powers so many different things it will be a pain to figure out where it's coming from, I would check in the kick panel for water intrusion first if it were me. Corrosion can cause a bridge and short a battery slowly, just like a dirty battery. Too many people don't realize that keeping your battery clean (not just posts and terminals) can lead to battery drain (not your case).
Battery posts and terminals look clean.
Yes, they do, from the outside. I'd pull the terminals now and inspect the mating surfaces. If the inside of the terminal looks dirty or dull, shine it up a bit with medium sandpaper. Same goes for the outside of the post, but you said it was a new battery... Clean it up a bit anyway.
You don't have factory terminals. That's not a bad thing, just an observation.
Do you have a ground wire from the negative post to the driver's fender, right near the battery?
Not what I was saying, but nice terminals? I was saying that batteries can have good voltage but inadequate amperage. And to check your plugs etc... In the kick panels for corrosion because bad enough corrosion can cause a bridge to form which shorts a battery....much like having a dirty battery does.
Yes, there is a clean solid ground from battery to fender.
Gil dropped off the truck this morning.
So here is what we have so far;
New Battery
Battery Terminals are like new
Connections are tight
Alternator is charging
No drain in system other than ARB Fridge
New Ignition Switch and key tumbler
Then I remember asking Gil when this all began and he said after the last starter he put in.
So we yanked the starter and found this, contacts are almost toast which will definitely cause his dilemma of intermittent starting.
In one of the photos you can see the difference in thickness of Gil's vs. another plunger.
This looks to be a poor representation of a rebuild or lack of on this starter.
Now starting on the rebuild of the starter and hopefully bringing an end to your no start issues.
If that's a recent 'rebuilt' starter I'd be taking it back for a refund...
I presume that's not a Toyota Refurbished starter then?
I'd check the brushes too and clean between the commutator slots - FSM explains it.
cheers,
george.
That's why I didn't think anything of it the first time I asked about the starter but after opening it up, it's a whole other story.
We are going over everything, my father was actually an electrician and would rebuild Alternators & Starters daily from 1980-2008.
Ready for pick up :cool:
Anyone one of the four cruisers on the lot could have easily crawled completely over that McLaren.
