Electrical dilemma
I recently had to replace my ignition switch. It would intermittently not work. I knew that was the cause Beecher my remote start would still work.
I saw a thread recently where a guy bought a reman starter and it failed quickly because the contacts weren't replaced flush. Perhaps your starter is bad already?
Perhaps. But not likely since when the stater gets proper voltage it fires right up. The starter cables may be a problem though.
I did that last week. Replaced the tumbler and the switch. Forgot to mention that in original post.
The other switch that is in the starter circuit is the Neutral Start Switch (NSS). There are many mud threads that have documented problems with the NSS and the connector going to it.
From your original post:
Summary of problem: 1996 80 series. LC intermittently has trouble starting up.
xxx
This morning, truck did not turn over at all. Battery showed 12.3v
Came back later in the afternoon and jumped with Microstart. Did not turn over at all.
Jumped from vehicle battery to LC and started right up.
Even the Forum famous NLXTACY traced down a parasitic drain that no one else found and we're still having troubles here.
Your parasitic drain probably ran your battery down a bit, hence the 12.3 instead of 12.6 to 12.7 fully charged. It still should have turned over the starter although slower than normal possibly.
When you say "did not turn over at all", did it even click? A low battery would make the starter rattle.
You didn't even roll the starter at 12.3, and nothing helped with the Microstart. However, when you put cables on it from another vehicle, it fired right up.
This tells me you have either dirty connections at the battery or your new battery took a s*** already and something is failing internally.
Jumping it with another car doesn't change your cables, starter, switch or anything else. So I'd be much less likely to suspect those.
Pull your connectors off the posts, inspect them, clean them, and reinstall and use a good terminal protector spray such as Lynx.
Can you post up a picture of your battery and the terminals? Preferably before you dive in and clean it?
@Dr Gil I have a very similar problem, but it only happens every once in a while. Mine is definitely a short in the starter circuit somewhere. I'll definitely be keeping an eye on this thread to see if you figure it out. Also, if you need an extra pair of hands for help I'm up in Northridge. We met at Joey's a while ago, right after you mounted your winch. I'd be interested to see how to fix the problem.
You do know interstate recycles batteries. You could have got a rebuilt one. Take it back and ask them to test it. Not with a multimeter but an actual battery tester. It will tell you if you have a bad cell. It could still have over 12v with a bad cell...
As mentioned above, if nothing worked until you jumped it with another vehicle it may in fact be a bad battery, had it happen more than a few times working on other peoples rigs. Batteries can show decent voltage but have next to no amperage output which makes the job of starting a real PITA. My brother and I owned and operated a small shop together and we saw several of these cases. Swap a known good battery of the correct cold cranking amps into it and see where you are. As for a power drain in the dome circuit, if it's killing your battery that's one hell of a drain or one poor quality battery. Since the dome circuit powers so many different things it will be a pain to figure out where it's coming from, I would check in the kick panel for water intrusion first if it were me. Corrosion can cause a bridge and short a battery slowly, just like a dirty battery. Too many people don't realize that keeping your battery clean (not just posts and terminals) can lead to battery drain (not your case).
What is your DMM telling you now that you've tested everything?
I learned from working on naval vessels that sometimes everything can check out but the equipment is still not working. Sometimes, for whatever reason, a crimped connection will have poor conductivity. If you suspect this is the case remove the lead and flow some solder through the connection before reinstalling. This will greatly improve conductivity. This has solved problems before, but as others have said it's important to pick a starting point and check each lead, connection, and component in the circuit. You're already doing this.
Update:
I charged the battery for 30 hours. I measured with a good quality meter:
13.3 before cranking
10.4 at lowest while cranking
11.4 with headlights on while cranking ( tripled checked this reading)
Pictures of battery terminals to follow later
Update:
This indicates a bad battery to me. 10.4v under load indicates there's no charge in the battery, yet you had just charged it for 30 hours. So there's a bad (shorted) cell in the battery.
I had a similar problem. One mechanic told me that as the flywheel gets old, sometimes the gear gets worn just enough that the starter gear does not makes a good contact. He recommended me to do the old VW-Ford starter solenoid install to give an extra boost to the starter. I'm not quite sure if the wiring explanation on the picture is right. Look in any old VW forum, most likely you will find where the wires go. After I did this, about 6 years ago, the problem was gone. One thing he stressed, it has to be a Ford OEM solenoid, not a chinese made...
Update:
If that is measured right at the battery terminals, then your battery is pretty knackered (even after 30 hour charge), likely a dead cell as has been indicated above. So, that's problem #1. Starting Lead/acid batteries don't like being drained down and presumably your parasitic drain has been taking its toll on it over a period of time.
Next you need to identify the parasitic drain current (i.e. how much is it?)
cheers,
george.
A multimeter may give you the vdc reading but that isnt really telling you anything. Take it to interstate and have them test it with an actual battery tester NOT A MULTIMETER. It sounds like a dead cell for sure. It happens. Personally I like jel cells because of the heat here...
A multimeter is fine as a test if it is measuring voltage when the battery is loaded. Cranking is a pretty decent load (several hundred amps) so measured voltage across the battery terminals will give you a good indicator of battery health.
Open circuit voltage of a battery on the other hand tells you very little regarding the health of the individual cells.
cheers,
george.
Update:
Bad battery dude.
cheers,
george.
That's basically what I just said in other words. A multimeter will read voltage but not test the cells. You can still have 12+vdc with a dead cell
