I also postede this on PBB. . .
I have a SBC that the previous owner converted to an electric fuel pump. My original pump went out and I have replaced it with a new inline pump (Carter) mounted to my frame rail. My problem is that the pump seemed to run fine Saturday when I installed it (pressurized the system and then only ran when there was fuel demand). Yesterday the thing would run continuously (both with the ignition on accessory/motor off and when the motor is running) and not seem to pressurize the fuel system enough to turn off.
I have checked my fuel supply and I am getting fuel. I have all new hoses & filter (all rubber 5/16" hose) and there is no fuel leaking anywhere. I even pulled the connection to the carb and plugged it checking for a leaky carb. No luck. It continues to run.
Am I correct in that the pump should pressurize the system and then stop running continuously? Any other thoughts? Is it okay for these pumps to run continuously? Also, my local Napa guy suggested I go back to a mechanical pump as thay are more reliable. Any thoughts on that?
Thanks in Advance
Thanks in Advance
