Is there an oem electric fan option out there that is ideal for an 80? My fan got into my radiator today and put a hole in it. Looking to go back with electric when I put it all back together
Yes.Have you seen this turn into an issue?
Recent work:
- Engine mounts (over 2 months an 2000 miles ago)
- Coolant drain and fill + Thermostat (4 weeks ago, fan and shroud came out for this)
- Broke upper nipple on radiator durring the above service, JB welded in a fix, ordered a replacement radiator
- Fan punctured radiator at base 2 weeks ago (about 150 miles after service)
- Removed old and installed new radiator. Clocked the trans lines the best way I could, shroud did not fit perfectly in the folders but was close.
- Idled to burp system, no noises from the fan hitting shroud
- Drove 10 miles to my buddies shop with a kick down full throttle application only at the end of the drive once
(suspect this did it)- Cut radiator in same fashion
Based on the evidence I think the leading edge of the fan was catching the shroud and deflecting in toward the rad core. I would've thought this to be impossible based on how rigid the blades are but some stretch marks on several blades supports this theory.
Things that could be causing this.
Combined with any of the following
- Perhaps my DS engine mount is set lower than it should be?
- Improper Shroud Seating / positioning.
- Clutch is failing allowing fan to move forward? (seems unlikely)
- Evil under-hood gnome with a sledgehammer bashing my new s*** cause "he doesn't like change"
