While running some errands on the weeked, while getting on the off ramp getting off the freeway, heard a hissing sound startup under the hood near the firewall accompanied by slight loss in power. Pulled over and found the vac hose that connect to the lower port of the EGR to the EGR Vacuum Modulator had come off and was venting exhaust gas!
After cooling down, put it back on to get home and it did it again on the offramp nr home. No CEL codes thrown during either time.
I started ging thru the OEM manual and my notes on the last time i replaced the EGR, Modulator and VSV -- was back in '05 and ~ 50k mi ago -- and did the EGR tests on the truck. With engine cold, and at idle, and a hand vacuum pump on one side of the T (and the other side of the T blocked off), I was able to pump a sm amt of vac and get the EGR to close, causing the engine to stumble. I think the EGR is ok. Was able to do this several times to convince myself: apply vac to the T, get the engine to stumble and then release; repeat.
EGR Vacuum Modulator appears ok too. Pulled the cap and looked at the foam filters - some dust but clean and no burn marks. Vacuum seems to pass with a bit of restriction. No burn damage as others have mentioned. I did pull over quickly and may have avoided destroying it.
VSV is hard to get w/o pulling intake apart so could not check that and listen for the solenoid to click.
And, again, CEL codes!
What's bugging me is the exhaust gas coming out that lower vac port at idle even when cold -- its coming out all the time! Looking at diagram on pg EG-114 in oem manual, that lower port on the EGR IS shown to be connected to the exhaust. I never checked this port before so dont know if this is 'normal'. That diagram for the lower vac port on the EGR sure indicates that exh CAN come out. IS THIS NORMAL?
Scouring MUD over past couple of days - found these threads:
https://forum.ih8mud.com/80-series-tech/427493-egr-valve-aka-blowtorch.html
https://forum.ih8mud.com/80-series-tech/363575-p0401-defeated-pics.html
https://forum.ih8mud.com/80-series-tech/399227-loss-power.html
https://forum.ih8mud.com/80-series-tech/28195-unhappy-80-cat.html
P0401 Defeated - with pics link has some great pictures of the intake the plugged EGR port -- I did clean my intake and all the ports when i did the HG in '07 or so but they could be plugged. Would that cause the lower EGR port to vent exhaust tho?
I just pulled the rear catalytic convertor out - it was the easiest to remove of the two - to see if it was plugged. When I hold up to the sky, it looks like ~ 60% of the square holes in the cat are plugged. With the rear cat removed. started up the engine - still cold and at idle - and there was still exhaust gas coming out that lower EGR port when i removed the hose. It may be coming out at a slightly lower pressure but hard to tell. I would have expected to see almost no exh coming out the port with the one cat removed IF the cat was plugged. But, the front cat could still be plugged even more - no easy way to tell.
Replacing the cat's in CA does not look to be easy nor cheap. OEM's from CDan are just under $2k for the pair. And the EGR SEEMS to be working. Throwing parts at this to troubleshoot will be expensive. The EGR is not that old either. I have had the 80 since new and this is the 2nd EGR I believe - maybe the 3rd (still looking for my repair notes from the HG.)
Anyone noticed with a well-running 80, does the exhaust always come out that EGR lower port at all times??
Appreciate any ideas. Thanks in advance!
