I started to throw a dreaded P0401 code that was constant, and recurring immediately after clearing.
I have the FSM, and read God knows how many EGR and P0401 threads - More than enough burn my eyeballs and confuse the hell out of me, so I decided to dive in.
Preparation -
I had decided to take the upper intake off - the better to see what I was doing and learn what is under there - as well as replace the vacuum hoses under there. I also decided to pre-order the apparently most common failure parts - The VSV for EGR and the Vacuum Modulator (right off of the EGR valve, had previously tried to clean - it looked rough).
First: I will list the parts I ordered and or used:
-Throttle Body Gasket 22271-66010
-Upper to lower intake gaskets (2) 17179-66010, 17171-66010
-VSV for EGR - 90910-12079
-VacuumModulator for EGR - 25870-66011
-EGR Valve Gasket - 25627-66010
-Water Hose Clips for hoses into TB - 96135-51300
-5/32 ID Vacuum hose - 'bout 9 feet total
-1/4" ID Gas line hose (for gas and water lines replacing)
-5/16 ID vacuum hose - Bout 2 feet-ish
-Fuel Filter - 23300-69045 - It was right there - might as well...
(edit to Add cleaners)
-new bottle of Simple Green for general cleaning and de-greasing without harshness
-two cans of Throttle body cleaner
-Spray bottle of water to wash Simple Green off of engine
-Cleaning brushes - Tooth brush, nylon brushes, etc for cleaning
-Lots of the Blue paper shop towels.
(I was doing this in my garage, did not want too harsh of chemicals hitting the floor)
-I cleaned parts requiring Throttle Body Cleaner on an oil drain pan - the kind that has a hole in the top keep the oil until you can dump it - so solvents drained into it and did not have risk of spilling in garage.
I had a very dirty engine to start with, thanks to recent rain and big Vegas desert mud puddles. I took pictures of all assemblies prior to removal, in case i had trouble remembering how it went together again.
-I removed the Air cleaner and MAF sensor, intake hose, and per the FSM, removed the throttle body. It was very dirty, doubt it has been cleaned in the engine's 15 years.
-Removed the EGR Valve.
Here is what the intake and throttle body looked like:
Preparation -
.... Plugged it with my finger and the engine settled down and hummed.
Now three days later, code is gone, it is running smoother than before, and a pinging I had is now gone.
WHOOO HOOOOO
thinks I'm like a friggin' mechanic or somethin'!
