EGR hose blows off - plugged catalytic convertors?
Just a followup to complete this post:
After some weeks of drviing around locally, I have been hearing more rattles from the front cat area - like rocks in a sheetmetal box - and a reduction in performance. I can hear the S/C working most of the time though I am able to run at freeway speeds. The 80 feels like a slug, working hard. The rattle is always there as I accelerate, disappears at a certain rpm, and then reappers during de-acceleration. Classic vibrational resonance.
I think more of the front cat has come loose and plugged more of the passages. I guess its time to find a replacement cat...
So it's not just the metal heat shield rattling, right? If it sounds like the ceramic monolith inside the cat is breaking apart, can you lightly hit the exhaust with a rubber mallet or something and recreate the sound? When the exhaust is cool, of course... :P
Can of rocks. And its not a loose heat sheild. Shield is nice an solid.
When I pulled it off the first time, cleane out the rocks -- bits of worn mesh material. Took an hour. Really hard to see from the back side -- only access without a bore scope camera is thru the O2 sensor hole, as the bits pass back in forth while shaking.
Am guessing more broke loose as I drove and re-plugged the opened holes.
Its $50 for all the gaskets if i pull it again to re-check. Tried re-using the gaskets and ended up w a leak so had to pull it all off again and put new gaskets. Real pain. Worth having a spare set. And, then there is the pleasure of those exh manifold studs that like to come out of the manifold flanges...
The EGR hose blowing off happened to me on my '94. The cats had actually disintegrated to the point of their guts migrating into the muffler and almost completely blocking the exhaust flow out the tailpipe. The truck could not maintain speed. I dropped the muffler and shook it and big chunks of cat guts fell out.
My remedy was to just finish gutting the cats, clean out the muffler as best I could, and reinstall everything. Not sure how well that plan worked out, as I've only put about 10 miles of 'wheelin on the truck since that happened 4 years ago. :doh:
Resurrecting an old thread to post what I found with this problem.
This thread was helpful to me to think through what I needed to do, so thanks to 'mud for the collective knowledge.
My car is a '95, so two in-line cats, 166,000+ miles, Supercharged for 110,000+ miles, 33" tires, I pull a small trailer frequently.
I have been experiencing noticeable power loss over the last couple months, but blamed climbing in the mountains at elevation.
Finally, on the freeway last week, the characteristic whistle noise from the engine room, and very noticeable loss of power.
Pulled over, and the rubber hose from the EGR valve to the bottom of the modulator had blown off.
Having never heard of this particular issue, and being away from home, I plugged the hose back on only to have it blow off before I got back on the freeway again. The top plastic insert on the valve cover is now melted.
Recently I had a new muffler installed and I immediately blamed it on a bad muffler, too much back-pressure.
The muffler shop assured me that this muffler would not cause that problem, but went to the trouble to do a back-pressure check before the cats.
Results: at idle about 1psi, 2500 rpm around 3-4 psi, but the engine had not been warmed up, no load just open throttle.
He offered to cut the cats off, inspect them and re-install them if they were OK visually.
I told him to go ahead and the result was very telling.
This is the front cat:
The brick in the cat is significantly melted. I can see why it still flowed, but at full temperature probably had much more resistance to flow.
The rear cat looked OK but had remnants of the front cat inside.
Conclusions:
- back pressure checks are informational, but should be done at operating temperature, under load, and should be very low, probably less than 3 psi, although right now I don't know for sure what the typical spec is.
- this is one of those surprises when running a supercharger that I didn't see coming, but it makes sense now - so much air and at a higher operating temperature and more temperature swings. The injectors can't keep up enough to keep the cats cool, they're already almost at max duty ratio at 6+ psi boost under load.
- do not clamp the rubber hose that runs the EGR valve to modulator valve, this is the 'fuse' that tells you somethings wrong - pay attention!
- it could be an old hose, but if it happens again after replacing it with the same type of hose, fix it right.
- my recommendation would be to replace both cats at the same time, don't try to save the rear cat, if the front one has gone bad, the rear one is toast as well. You'll just be in there again replacing the rear one soon after.
Remedy:
I had two new cats installed (aftermarket) fully realizing that I may be back in 5 or less years doing this again, but, life in California.
The exhaust sound is SIGNIFICANTLY better, less restricted sounding, engine has noticeably more power, feels like my old supercharged 'Cruiser again!
I will replace the EGR modulator (not the EGR valve) and the rubber hose with OE parts - 'cause I'm an OE kinda guy.
Here's to hoping it lasts! ;)
Dan.
PS: If you're in Southern California, specifically Torrance area, I recommend Sweeney's Custom Muffler. Good guy, conscientious about his work, lots of experience.
Im having the same issue! Just posted about it earlier tonight. I put a new hose on between the egr bottom port to the bottom port of the modulator and resolved the hissing issue but the truck is running like crap! I just bought this truck less than a thousand miles ago and it supposedly has two new magnaflow cats on it or at least i have warranty cards in the glovebox for them. I cant believe im going to have to drop the exhaust and do all this! The truck has been running great until last weekend! It died on the freeway, got towed, when i got it home the coil wire to the distributor was disconnected. Fixed that and it started right up so i thought it was good to go but then the hissing and no power. Now hissing is fixed and no power.
Secondary cat, concrete inside. Completely blocked w all the internals of the primary cats internals. Primary cat just had some some chunks still left in it but otherwise clear. Replaced w new magnaflow ca compliant downpipe and cat along w magnaflow secondary cat and problem solved.
One thing I will say about the magnaflow, the second cat seems like it has a mfg defect, its clocked wrong orientation wise as far as the cat housing. It should line up w the primary cat. I submitted a support ticket to them, hoping to get a warranty replacement.
