Ebay Power steering kit
Houston TX
Looks like the mini-truck kit that JT Outfitters sells, for about the same price. IMO this is the best way to add after market power steering. You retaing all the original linkage but there's no cutting the frame or welding.
Funny, I would say it is one of the most expensive and weakest power steering systems out there.
Before you buy it,, make sure the input-shaft has aprox. 4.5 turns... I've been burned on those boxes before that turn about 3.25
Thanks
wesintl said:
search tool is your friend...
https://forum.ih8mud.com/showthread.php?t=65318
could probably be done for less than half that if you want to source your own parts...
I did a search for "ebay power steering" but this is exactly what I need. Now I just need to decide if I want to buy a rig that needs alot of work as opposed to the DD ready rig I intended to buy.
Thanks Again to all for the reply, I am gonna watch it to see what it goes for.
If you could find someone to weld what you need; a sag kit from say Cruiseroutfitters would be less then half the price of that kit (not including the fab work). But with the fab work I bet its somewhat a little more than that kit and a whole lot better set-up in the end.
Hey Mace. You know John Ermakovich that was out there at GGG with us brought some of this stuff by my shop a few weeks back. Showed me how the mini box succeeded in physically ripping the ears off of his factory center arm!:eek: I'll have to take a pic.
P/S Brackets
I have both brackets to do the Mini truck gearbox and
the Saginaw P/S pump.That includes all the mounting
hardware,spacers and adjusting arm.
They are $95.00 each plus shipping. If you buy both
they are $180.00 plus shipping.
Send me your address and what you want and I will
email you a total.
You can see pictures at the below web site and a good
post on ih8mud. Thanks
Bill
http://photos.yahoo.com/wdorry
Dam,
Apparently I can be very wrong ;)
I did it twice to the early style arm. It is because I am a dumbass and did not turn out the stops. WHat happened on mine was that the swamper lugs grabbed the relay rod, forcing it down, breaking the arm. When you turn your stops out it limits the steering so much that I thought I would just be more careful rather than crank them out. I wasn't.
The mini conversion has worked great for me for 6+ years (the breakage was my idiocy)and up to the 34" tires. With the 38's it is time for something else, probably 60 steering.
The mini steering is great for a DD, and light wheeling with under 35" tires, but the sag and the 60 steering gets rid of all the relay rod (coming DAMN close if not hitting the shock), center arm, and all the associated BS.
agree, get rid of the whole push pull crap if your going to go ps
