- Year
- 1991
- Vehicle Model
- 80 Series
- Location
- Idaho Falls, ID 83401 United States
- Mileage
- 109000
Vehicle Specs:
Recent maintenance:
Contact for more info.
- 1991 HDJ81
- RHD JDM Import
- VX Limited Trim
- 1HD-T turbodiesel
- A442F Automatic Transmission
- Axle Code K295 (4.10 final drive, rear LSD)
- 109k original miles
Recent maintenance:
- New brakes front & rear
- Big end bearings done (BEBs) and oil pan resealed
- Engine air filter, fuel filter, oil filter & engine oil (Amsoil 15W40)
- Timing belt, water pump, front camshaft seal, coolant drain & refill
- Front knuckles done - including wheel bearings, all seals, inner axle seals
- 3" exhaust upgrade
- A/C fully rebuilt (compressor, expansion valves, all gaskets) and refilled with R134A at the Toyota dealership. Yes, the cooler box works great!
- Front end alignment and replacement of all steering linkages/tie rod ends
- ACSD delete
- Professional undercoating
- 5x 33" Falken Rubitreks
- Bull bar, roof rack & rear bumper
- Transmission fluid change (Amsoil ATF)
- Gear oil change in transfer case & both differentials (Amsoil 75W90)
