- Location
- United States
Im looking for a spare tire carrier for my 1964. Any leads?
Hinges at the back. I actually have the hinges, just not the carrier.one that attaches to the side of the tub or one that hinges at the back?
PM sent.I've got the bolt on piece if needed.
My old 63 just had the bolt on piece on the side of the tub. no rear carrier.
So my ‘63 is 11 units earlier than yours Paul (based on registry). That doesn’t seem like enough to justify different tire racks - mine is swing out in rear. At least the upper mount holes and body support are there, bottom holes and structure are in rust heaven. I picked up the carrier from John. There are also the mount brackets for the under bed carrier along the cross member that has the upper shock mounts as well as the sway bar brackets. And the little bracket the carrier locks into on the underside of the rear cross member is also there. But no carrier. What’s with all the options in a short time period?
Sounds good. PM inbound.I've got the bolt on piece if needed.
Yes. Functionally the same, and even visibly with tire in place. The early ones look like this:Early used thick washers attached to space out lug holes in stead of raised pressed metal, can't tell when tire and hubcap is on.
When did the stud to hold a lock start? Can't remember if my later 62 had the spare tire carrier or not. My early 62 FST tub still has the carrier attached and does not have a stud.
Locking stud is a mystery and may be market specific on early cruisers. Here is a pic of FJ25 that has locking stud on spare tyre carrier.
My '64 is very early, 23mm lugs, build date of May '63 (approx). The spare carrier is definitely original with lock stud. Original paint was the same bandaid as in the rest of the truck.
True. But between the original bandaid paint and the presence of paint matching all 3 subsequent color changes, I'm convinced.Really hard to prove a spare tire carrier is original this many years later.
