Wanted Early FJ series Speed detectors
my book for canadian models shows multiple groove (2 and 3 ). I was thinking these were a/c equipped ! I can't get an accurate part number to obtain from dealer so I will have retro-scab something to get it to work for what I need ! thanx for the info!
Water pump pully? I've never seen a three groove pully on a 3B water pump. I think you're trying to ask for a crankshaft pully which is where the a/c belt goes.
I have some but I'm in Canada so I'm no help.
Looking for a 5-speed
I am looking for a 5-speed or any adapters for my fj-55 with a 2f using the stock transfer. If you are not using your parts, i sure could. It can be a nv4500 or a toyota 5-speed. Don't matter none!!! Thanks
We Need Two Techs Badly! In Denver
we need to hire two more real good import experienced(nissan/infiniti/toyota)technicians.
ANYONE NEED A JOB WRENCHING?
willing to relocate to colorfull colorado?
let me know and i'll hook you up with my service manager..... :D
Exactly, the crankshaft might have as many as 3 grooves but not the water pump.
The pre-power steering models had a single groove crank, with power steering there is two grooves and either a spacer or a pulley for A/C in the middle.
one groove on the waterpump pulley
one groove on the crank pulley is factory/no options.
Then you can add a PS pulley and an addtional AC pulley to get three grooves at the crank
you will need 2 idler/tensioner pulleys that are seperate for the PS and AC belts
depending on the year of your 3B, you may need to get a lower crank pulley/dampener that has bolt holes and flat surface to bolt the the PS and AC pulleys to
I have the parts here and I can get you some pics if needed
Just fyi, I had a tough time finding it for my 77. Ended up getting what I needed from a local guy that does a lot of resto's and weber conversions. So what you're looking for may be a tough find.
p/s pulley from a 91-92 fj80
fj62 pulley will not work
would also be interested in the whole pump for the right price.
looking for door hardware for half door project...
drivers-side regulator
exterior and interior handles/latches...
thanks,
manny
