Early cluster LED upgrade
East Glenville, NY
Has anyone upgraded there instrument cluster bulbs to LEDs in a 73 or earlier cruiser? I am having a hardtime crossing the #s and the folks at SuperBright LED.com aren't much help. Any help would be great!
Chris
I searched and found only info for the newer rigs..... somebody has got to have this info. Or, what bulb # did you use to replace the stock ones. That would be helpful maybe to cross reference the bulbs
Upgraded to the white LED's nice and bright # BA9-CWHP6 12vdc from Superbrightleds.com. Two picks with different ASA Settings, guess I should have cleaned the glass first...:doh:
Man, those look great, must be nice to have a cruiser with only 19 miles on it too!
an upgrade I can afford
Thanks for the bulb number. This is one upgrade I think I can add into the FJ40 budget with setting of the spouse alarm.
Installation is a bit tricky as you cannot plug the LED's in from the back they have to go in from the front of the console so you will have to take the console out, but really it should only take about 20min and it is a major, major improvement!
If you are going to order bulbs #BA9-CWHP6 for your instrument cluster go ahead and get bulb# BA7 as it fits inside your head light switch to illuminate the lettering. It makes a drastic difference at night and makes the lettering really come alive. I have replaced all of the interior and exterior lights on my 40 from Superbrightleds. They have bulbs to fit everything on your 40. Leds really lowers voltage running through that old wiring.
early rigs don't have lighted headlight knobs
I was just throwing out the info for those that do. I believe they started in late 72 or 73.
Depends on the L.E.D. Some don't have a christmas tree look.
another easy way to get more light is to remove the little tabs in the back... took me 15 min cost me nothing and I can see my gauges just fine now!
Correct but there is just something cleaner about a whiter light and not a yellowish one. It makes me feel as is the charging system is working better than it really is. lol Though you do lose the dimmer function when you switch to LEDS. Best part of having LEDS are the indicator lights are brighter.
