Early cluster LED upgrade
EL wire... Kickass Stuff For Your 40-Series
Installation is a bit tricky as you cannot plug the LED's in from the back they have to go in from the front of the console so you will have to take the console out, but really it should only take about 20min and it is a major, major improvement!
Refreshing an old thread...
The previous number listed isn't available any more. I went with the BA9S-WHP (25 lm) without tabs removed and pretty happy with the results. I think this would look pretty good as well with the tabs removed if you like a little brighter.
@primer7, thanks for the heads up on installing from the front as they wouldn't fit through the back & I was scratching my head.
I also used the corresponding colored LEDs for the turn signal, brights & brake warning light (BA9S-?4-32-12VAC) which all look great. Not too bright or dim.
I went with the LED ribbon, against my own desire to stay stock- can always revert back. The yellow looks right- cool white was too new looking.
Make sure the upper one is right along the front edge, otherwise the passenger can see the LEDs. The lower one can be a little further in.
(and yes, I know the white 1/10's is on the left side- the PO/my best friend was able to fix the odometer by moving it over- man, was he smart)
Did you guys use 6V or 12V? The BA9 bulbs require choosing a 32 degree beam angle or 90 degree. I've got no clue which. If y'all know quantity for gauge cluster and tail lights/turn signal/etc that would be awesome too.
