E-Brake issue
Reno NV
This weekend I took my 76 FJ40 for a drive around the neighborhood, nothing special, really just moving it. After a few blocks, I started hearing what I am considering is my e-brake starting to rub along the outside hub where the shoes would make contact. It's almost like they were slowly expanding without the e-brake handle being pulled inside the 40.
So just a few moments later, the dragging sound is a little louder and can now be felt while driving that I'm being slowed down. I start to slow down a little more and pull to the side when it comes to an abrupt stop. I drive again in 1st but immediately stops me again. I put it in reverse and low and behold it releases the brake and I am once again able to drive the few blocks back home with no issue. Although I think iirc I could hear the dragging sound still ever so slightly.
Some back story on the e-brake, I did rebuild it recently after getting resealed transmission and transfer case at Valley Hybrids. The e-brake cable was not replaced, but shoes and whatever comes with the e-brake kit was replaced. A while ago after rebuilding it, I never adjusted it so that the e-brake would actually engaged when pulled, so I adjusted it and then found it was too much and I couldn't move the 40 after I had pulled the e-brake, like it never disengaged. So I adjusted it even more back down and problem went away, but maybe I guess I still need to go another turn down.
I'm pretty convinced this is the e-brake, do I just need to adjust this further down so I don't have this issue? Is it not the e-brake but something else?
Anyone else seen this same issue?
Two things come to mind - the spring on the ebrake shoes isn't pulling the shoes back from the drum reliably, and your ebrake may be adjusted too tight. There should be 7-9 clicks as you pull out the ebrake handle.
I would drop the driveshaft and study the ebrake. Drum brakes tend to be self-energizing in one direction, so it's not surprising that after your truck locked up, the ebrake released when you backed up the truck in reverse. In any case, I think your ebrake shoes are 'going wild' inside the drum and randomly engaging or engaging during forward motion.
I presume the parking brake drum was blazing hot when the brakes engaged hard enough to stop the truck? That would confirm that this is an ebrake issue and not a service brake issue.
With the drum off, I would exercise the handle and shoes and see that they move in/out freely as the lever is pulled/released.
I found an aftermarket cable for my Pig that was longer than stock...
Before I bought a new cable, I would open up the entire assembly and confirm all components are properly installed and still attached as it sounds to me like something came loose (which has happened to mine & with same symptoms)
That's good to know you had a similar thing happen. Yeah I will definitely check those things out first. Thanks.
So to put an end to this thread I did exactly as mentioned. I started off by thinking it was the cable and found out it was much more...
