Dynamat the LX
Gilbert AZ
did the factory do sound deadening differently in LX vs. LC?
Yes the LX has a lot of factory sound deadening. I would not put anymore dynamat in a LX unless you want to put some in the doors. I just added thermozite insulation under the carpet and it makes much bigger difference than dynamat ever could for fraction of the cost.
LC has 90% of the floor sound deadening. Door not so much.
Does anyone have a photo showing the floor (with carpet removed) and the door (inside view of the metal skin/panel) of a LX450 to compare with a FZJ80?
Were there any differences in the carpet or carpet padding?
If it was me and I was looking to make the truck quieter without just adding more and more weight. I would use dry ice and remove the old ineffective factory sound deadener without a constraining layer and add a modern version of Dynamat, or preferably Sound Deadener Showdown CLD tiles. If you just add a deadener on top of a deadener it is like trying to stiffen jello by putting pudding on top of it. I will be doing my LX this way soon, but I will be using the 25% method to keep weight to a minimum.
Where did you score the insulation?
