Dynamat on doors...
Dante's Inferno, CA
Hey all...have an expensive set of speakers in route for the doors. "While I'm in thar", I'm looking to replace all window runs and clean up the window motor, etc. I'd also like to Dynamat the behind the door cards to help cut down on some door rattle that will likely be evident after upgrading the entire sound system. Any tips/tricks/pics of successful Dyanamat in the door panels would be appreciated...:beer:
I've used dynamat in the past with good results but never on the 80. My advise would be to install it on the inside of the door skins, don't worry about total coverage(30% coverage is more than enough), make sure where you install it is clean(simple green on a rag followed by acetone or wax and grease remover would work nicely but as long as it clean the method isn't important), make sure to press hard while installing to get good adhesion and don't just slap it on all at once("roll" the sheet on to avoid air pockets). Truthfully its really easy to do and I think you like the results.
I put some around the hole the speaker goes in behind the door card (maybe 2" around the hole) but that's it. The rest went on the outer skin.
Outer skin as in the backside of the door sheet metal?
I did it. It's not bad but you will scratch the s*** out of your arm reaching up in there. I cut small squares and did the best I could. Shutting the doors sound solid now without rattles. Kinda like a Lexus with its cladding.
Do your doors rattle at all from music/bass after the Dynamat?
did it as well. Just take your time and beware your arm/elbow/wrist in contortions
Dynomat is only sound deadening, if you got expensive speakers coming I would also put a layer of heat and sound proofing mat/high density foam. Cheapest way is high end carpet pad, there are more car specify products that cost a fortune nut honestly they aren’t that much better. Key is high density foam and do at least half an inch of it. There are high end shipping high density foams that are really good but I don’t know where to source them. Denser the foam the better!
I thought about it but I’m too lazy. :rofl:
I did all four doors and the hatch. Not so bad. Be careful with the plastic weather sheet, you need to re-use that. Tighten up the window roll up bolts, and clean the rails and weather stripping rubbers while you are in there (as you mentioned).
I used, as wide as I can, and short in height strips of the Dynamat.
Qball is right about the sound deadening, but the Dynamat makes a big difference in road noise. Getting the Dynamat installed is a much much better outcome than "thinking" about getting 1/2 inch high density foam installed. :rofl:
Get ready to bleed... I did it on one of mine and it helped a lot.
I think I'll have my wife do it. She drives the 470 and has very thin arms. I drive the 80 and my arms appropriately fill out my polo shirt per @zona requirements.
Ha! I did my front doors with dynomat and didn’t help that much. Was going to add the pads but got lazy. For best result you definitely need BOTH! Roll on your dynomat or ratmat(you pay for the dynomat name) and spray glue the pad on top of dyno mat and it will feel like a Benz or lexus door if not better. The pad also helps a lot with heat in the summer.
If the foam density is high enough then you don’t really need the dynomat.
