Here is some $$$ saving advice that will land you a much better system in the end.
Forget about National Luna especially, and IBS too. Way too expensive, and those systems fail frequently. Go on Expedition portal and look up National Luna, and you'll find many complaints about failed systems draining both batteries. he heart of both of these systems is a cheap continuous duty 80 amp relay that you can get for $25 or less.
Instead, the Blue Sea ACRs absolutely rock. It's a much heavier duty product, engineered for boats and guaranteed "for as long as you own it". It's also easier to install, you can use your own higher quality cables. For a dual system, without push button jump start Use the Blue Sea SI-ACR 7610. For push button jump start and higher capacity (that is generally not needed in an 80) use the 7622. THe 7610 can be had for $75 or so on
Amazon, you make up your own positive and negative cable, plus one tiny ground, and you're done. You can add on dual inexpensive voltmeters from
amazon if you want to duplicate the monitoring function of the Nat Luna.
Seriously, the ACRs are much better, easier to install and cheaper, with a lifetime warranty. I don't know why anyone would install one of these "kits".
I also think that the Blue Sea 7610 is plenty for 80s, but you do get a few extra features with the 7622. The one key feature is the ability to self jump which is about a one time in ten years thing for me. Remember you can jump from any aux battery with a set of jumper cables that you likely carry anyway. And, since the ground is always connected, all you need to do is jump the + terminal.
Me personally, I think dual batteries are nearly essential. Not just for peace of mind but also for running a fridge, charging cameras/phnes/radios and some camp lighting. When you add solar, you'll want it to charge your #2 battery and since the ACRs sense charge and combine both ways, you can run your solar to your aux battery. Once it's charged, the ACR will combine and also top your main. During normal running, the alternator will charge the main, and once holding 13 volts (moments usually) it will combine and also charge your #2 battery.
