Hoping you can provide some advice on fixing my drum brakes on the front of my troop carrier.
I had to wheel cylinders with seized adjusters. I replaced all wheel cylinders with new.
Previous symptoms were a low pedal. I need to pump the pedal once and would have brakes on the second application. I thought this was caused by the lack of adjustment of half of the shoes.
I’ve since replaced all wheel cylinders and bled the brakes three different times. They still require pumping in order to engage. I’ve adjusted them from factory spec to so tight they can’t be turned by hand. Neither made any difference towards pedal height.
Well the truck is on the hoist and brakes applied one full application The front brakes are hardly engaged. A second Pump locks them up.
With the drums off one pump hardly moves the wheel cylinders.
All this I think is pointing to my master cylinder now but I’m really unsure.
Looking for any advice mud might have
