Now, I know what youre thinkin...
"So what, thats maybe 900 miles"
It's the longest trip I have taken and I will be wheeling when I get there.
I am mildly concerned about breaking down.
What should I bring?
What else should I prepare for?
Some background on the truck
I have had my LX for about 18 months and I have fully baselined it and then some.
Engine is rebuilt with 30k
New trans has 30k
new Tre's
tjm 58mm (or whatever) lift
Rides smooth as silk at all speeds
Dual optimas with a simple 500 amp relay - red top and a bluetop multipurpose. All fused with 100amp and 0/1 cable.
Aux fuse block in the back.
front Wheel bearings torqued properly.
Knuckles rebuilt
Brakes fresh
all wiring inspected and very solid.
New fusible links
Pss fixed.
Egr system rebuilt
completely New cooling system
New belts
New tires 315/75/16 Cooper MTP
Currently gets 11.5 / 15.5 mpg.
Issues I am concerned with that may leave me stuck....
1 Lots of play when rotating the front drive shaft by hand. Perhaps 1.5" of free rotation. With the front wheel up, the opposite wheel doesnt start to rotate until the other wheel has rotated perhaps 4-5". Is somethibg.about to break??
2 It has the startup clatter and no combo of oil, filter, priming or 90 degree adapter makes a diff. Oil pressure is within factory norms per the oil sending port and a pressure guage. ...scares me that something may be wrong witg the build.
3 Other s***.I am unaware of.
New trans has 30k
new Tre's
Knuckles rebuilt
Brakes fresh
New fusible links
Pss fixed.
Egr system rebuilt
New belts
