forum.ih8mud.com
Did you have the vibration before the 3” lift?Saw this in classifieds the other day from @Surfdc . Im sure most people are going to say double cardan.
For Sale - SoCal: LandTank double cardan driveshaft
*Sold* Bought this from LandTank just a few months ago in hopes to eliminate a driveline vibration. Turns out it was something else. Barely put any miles on it. For those that don’t know this is a dc shaft from a Tacoma that is cut, then re-tubed and sleeved. Then new u-joint is installed. Then...forum.ih8mud.com
I'm hunting my own vibration now. I'm at a 4" lift, but also had vibration with the 3". I have a double cardan DS, so we are thinking its something in the T-case. Gonna start with changing the oil tomorrow.
If you have vibrations with your 3” lift then a double cardan may cure it.I've got a 3inch lift and am in need of a new front driveline. What do you all recommend that i buy? Should it be double cardon? Not enough lift to warrant that? Thank's for helping the uninformed become informed!
No, I think it started with the 3" lift. I think in most/normal cases the double cardan would cure it, but not for me.Did you have the vibration before the 3” lift?
No not yet. I will do this before considering rebuild.Did you rule out the rear DS by dropping it, locking the CDL and driving it to the same speeds that causes your vibes? Often time the rear pinion angle is jacked up due to lifts.
Still needs to be changed.There's probably close to a zero percent chance of curing a vibration by changing oil.
So does anyone have a recommendation on which driveline is a good purchase? Any vendors on here that sell them? This isn't me trying to cure a vibration, i need one since mine is ruined.
If no vibes, then I would recommend a toyota OEM shaft. you can buy a new one, or I have a used front and rear for sale. No pressure. Here is the link: For Sale - SoCal: 80 series oem driveshafts, front and rear - https://forum.ih8mud.com/threads/socal-80-series-oem-driveshafts-front-and-rear.1243188/#post-13820479So does anyone have a recommendation on which driveline is a good purchase? Any vendors on here that sell them? This isn't me trying to cure a vibration, i need one since mine is ruined.
Do you want a drive line or a drive shaft? Front or rear or both?So does anyone have a recommendation on which driveline is a good purchase? Any vendors on here that sell them? This isn't me trying to cure a vibration, i need one since mine is ruined.
