Dripping new hoses
Jefferson City TN
Well everything has been going well since I got the HG done until yesterday.
I am still running straight water. So I got up, ran the motor after the sun had been on the truck for a while and it started leaking water(coolant) around a hose clamp on the firewall. I shut it off and let it cool down, added a little coolant to the water to replace what I had lost and started it again. This time nothing, not a drop.
I checked the clamp and it was very snug. So I drove it all day checking for water on the ground as well as touching the hose and it was always dry.
This morning same issue, but this time from the front lower radiator hose. Could this be being caused by ice in the lines since no coolant was present? If not what would be my next course of action. I just got her back together and don't want to break anything.
I am running silicone hoses... I did retain some of the factory hose clamps that are spring loaded, they seem to be where the leaking is as. Could this be an issue?
Sent from my iPhone
Aftermarket hose is often different size/wall thickness compared to factory, so the factory clamps don't work well with them. Silicone hose can be challenging to seal, they like to squirm, creep, often best to use the special silicone type clamps. Having pure water in the system in freezing conditions is asking for big trouble, like $$$$ problems.
Did you use anything to help install hoses?
Some silicone ones are picky, the breeze type clamps are the way to get even clamping that may be the difference between drips & none.
I am aware water in freezing temps is trouble. It wasn't suppose to freeze in our area but got down to 30. I parked in in the garage to keep damage from occurring. Going to put coolant in once I get an idea of why it is dripping. Probably tomorrow. I am going to swap out the factory clamps on the silicone...
Sent from my iPhone
I did not use anything, just slid them on and clamped them down.
Sent from my iPhone
Another example of someone trying to reinvent the wheel that Mr. T perfected. I don't know why anyone would use anything but OEM hoses. There are countless examples of silicone hoses leaking even with constant tension clamps. I just don't understand the thought process...
At this point I would be willing to go to OEM hoses. I replaced all heater hoses with them. How much would it cost to replace with Toyota(gates). Should have probably done this from the start.
Sent from my iPhone
I don't know exactly how much the Toyota hoses would be. @cruiserdan or @beno could hook you up. It is a conglomeration of specific hoses and bulk hose IIRC. Gates hose will be SAE inside diameter not Metric. OEM hoses were specifically designed for your vehicle. They work. And work well.
  • Like
Reactions: ppc
And while you are at it order some extra hose clamps from Dan or Onur when you order the hoses. The Toyota hose clamps are actually very inexpensive and they are great clamps. When I replace hoses I replace the clamps if they are corroded at all. Then I save the old ones for spares.
Gates isn't OEM. Many would say they're a suitable substitution. MANY would say to stay OEM. Check with Beno or CruiserDan for OEM, or try your local dealership to see if they'll give a Mud discount.
Emailed sent to Dan. I think Beno is out of town. I am going to wait to swap coolant until I fix the hoses. Temps are in the 50's here and high 30's at night. Just kicking myself right now. Going to be a pain to swap them and it was so easy when the head was off.
Sent from my iPhone
Sent from my iPhone
Well, for as often (not very) as you have to replace hoses it just doesn't make sense to mess with anything but OEM. It would've been easier without the head on but lesson learned.
Two problems with OEM spring clamps, despite them being superior in nearly every other aspect.
1, they do not conform well to non-round hard lines. If you bend your metal heater pipe outlet at the firewall AT ALL, which is actually pretty easy to do, OEM round spring clamps will basically always have problems.
2, they don't deal with different wall thickness hose well. If for some reason you need to replace a hose on the road and can't find OEM make sure you get a clamp too.
Personally I'm very happy with my gates green stripe and regular screw clamps for the heater hoses.
I am going to replace the OEM clamps I have to get me by and just not drive anywhere except around town and watch fluid like a hawk. Hopefully Dan or Beno can get me set up fairly quickly.
Sent from my iPhone
Water cools better than coolant so overheating shouldn't be an issue. It's the cold temp you need to worry about. And of course leaking all of your fluid out and then overheating. haha.
I use the OEM screw clamps @bloc, not the tension clamps. I've had to get by with non OEM hose for a few days before and never had any issues. But I agree with you on the tension clamps, they only like OEM hoses. Anything thinner and they don't work.
OEM hoses are a great idea until you learn that you have to buy assemblies to get the piece of hose you want... :(
I believe @cruiserdan might be able to suggest alternatives, where say a hose from CarX can be bought and used on your Land Cruiser without having to buy pieces you don't need. And then you can use your factory spring clamps.
It is completely different to get a non OEM hose that the Shaman recommends than one some flunky at VatoZone recommends.
I replaced all the hoses except the radiator hoses with silicone this summer. I reused OEM clamps when I could get them on the hose and the pipe and constant tension when I couldn't. I have zero leaks.
I think an important prep step that may get overlooked is to ensure the pipe is CLEAN. Sometimes stray bits of rubber or paint will be left.
Hope this helps,
Dan
Don't be afraid of the Gates if the OEM are cost prohibitive.
If you can go OEM then go that route.
I'm running quite a few Gates with no issues.
I ordered some Toyota clamps for the firewall hoses. The spring clamps are no longer stocked so had Toyota provide me with what they have. They gave me these, I do NOT recommend them. Had three leaks with them after rebuilding the engine. Go with constant tension band clamps. The spring clamps work great IMO but the wire hoops were nothing but a problem.
1153772
Like these constant tension clamps:
