- Joined
- Jan 5, 2004
- Threads
- 143
- Messages
- 6,766
- Location
- Paint Lick, KY
- Website
- www.globalsoftware-inc.com
While sandblasting my windshield hinges I discovered one of them has a sheared pin
I got a punch and quickly discovered the pin is stuck but good! I tried heating it up with a Mapp gas torch, baking it in the oven at 500 degrees, beating on it some more, got a pointed air chisel bit, cranked the air up STILL won't even budge!
So I finally figured I would have to drill them out. I had drilled about half way through one end when I realized there was no way I could drill both halves straight since I don't own a drill press yet. Then the old saying "If you can't make it work get a bigger hammer or use a welder" popped in my head.
If I tack weld the hinges on the back side so they are aligned what will be the best way to drill that deep of a hole straight? Even if I had a drill press I don't see an easy way of doing this job.
Thoughts? Suggestions? I may end up at a machine shop...
I figured I would have the machine shop drill them out to a standard size oiled bronze bushings outside diameter then get a steel rod to fit the inside diameter. End of any future problem. Just replace the bushings when worn.
I decided I had to justify the Xmas drill press purchase to the
, by showing her I saved money by not having to buy a set of hinges.
