- Joined
- Apr 24, 2003
- Threads
- 208
- Messages
- 2,210
- Thread starter
- #21
sixty said:you will need to redrill the drum for the CV bolt pattern. on my brothers fj40 he welded in the bolt holes on the c/v flange and re-drilled it to match his fj40 front output flange so it would clear his sm420. It is not a good idea to weld on cast without knowing its meturallagy but it has not broke yet although does not get much use either.
you might want to check the shaft to see if you need to change the pattern.
Also I don't think the 5-speed equiped crusiers came with a CV since they are longer and generally do not require them. they were only used on US fj60 withthe short 4-speed trans.
nah this one is out of a 5 speed fj62... my mate pulled it (and rolled the cruiser) himself...
i see... hmm, maybe if i use the CV on the diff end, redrill that flange, and use my existing slip shaft on the other end...
