Door Limiter ?
Anybody know where to find em ? I can't remember exactly what they're called. But they keep the door from swinging all the way around when open. The wife swung the door open last night and broke the mirror. In order to keep this from being an ongoing problem - which it will, I need to get some door limiters for a '69 40. I remember looking a long time ago when I first got it. Couldn't find em then. Took the doors off later and forgot about it. Now I remember why I was looking in the first place. They attach to the inside of the door toward the bottom and then connect to a spot on the inside of the cab. Is there another solution ?
Probably from my 84 Mini that I sold a few years ago. I spent months working on that exhaust. Anyway, I cut the U-bolt in half with the Dremmel tool. Heated up the cut ends with a torch. Pounded the cut ends flat with a BFH. Drilled em out, dug thru the box o' nuts & bolts for some hardware. Even found a couple thick rubber washers for bumpers. Pieced em in and tightened. They work great - no more broken mirros. I haven't bothered to rattle can them yet, but some rainy day I will. Won't be able to tell the difference between them and OEM. Total cost - $0.00 ! Better than the $200 CCOT would have cost.
