So these can just be wired up? Nothing special needs to be done?i use holagen puck lights there for under cabnets. they run on 12 volts you just get them from home depo. they are very bright.![]()
I just got a Dot-it LED light from Home depot. 3 Led using 3 AAA bat. ... about 9bucks
you can just wire them up. when there in the house they use a tranformer witch converts them to 12 volts witch you dont need.So these can just be wired up? Nothing special needs to be done?
But they're 120v???
The only thing it doesn't do is come on by itself when you open the doors.
