- Joined
- Apr 21, 2005
- Threads
- 115
- Messages
- 25,806
The red wire on the top of the lamp socket is the only it would work. If your using door switches that make ground then the switching base has to be the ground. While I don't own a 82 I have a tub and frame with other parts. I plan to up my 79 to almost options including the dome light. The brackets on the A pillar will had to be made or removed from a 82 or later. maybe some other vehicle. The 82 and later dome light with the door switch option is no longer available. The long bullet door switches I believe are still available from Toyota. A picture of the door will show how the door has a section stamped out to mate to the door switch.
