Dome Light Hacks
run a wire from the + on one to the + on the other?
^ um, NO.... Doors/domes etc are NEGATIVE switched to turn on, you could run a wire from the -ve of the front dome to the -ve of the rear dome so either turns on with the doors or with the dome 'switch'. Obviously the -ve switched on each dome. i.e. fish a wire through the headliner. I did that so a rear mounted additional LED light turns on with the cargo row dome (for camping etc).
cheers,
george.
I'm sorry for my electrical ignorance but what is -ve? I that just the negative side lead?
-ve = negative
+ve = positive
Just a short way of writing the polarity.
cheers,
george.
Nice thanks! Does the wire gauge matter?
Wire gauge needs to carry the appropriate current. Given the domes (assuming you haven't gone LED) are <1A draw each, even 18g for several feet is quite sufficient and a common gauge for automotive wire.
cheers,
george.
cheers,
george.
learn something new every day
cheers,
george.
And if I have gone to LED??????
Awesome thanks George! This is not the first time you answered my juvenile electrical questions!!
When my buddy wired my Clifford alarm / remote start / esspresso maker alarm, he tied all the lights together - you open a door, you get all 4 door panel lights & the forward 2 domes, all 3 if the rear one is switched to door mode.
It's nice to me, but I had to switch over to LED's right quick.
He said since he was doing the door pins as the alarm triggers, it was easy while in there to tie them all together - plus a certain button on the remote kicks the lights on too (some 'anti-carjacker hiding in your car' feature?) --I use it to wake the dog before I open a door & get hell from the bozo.
I tweaked all the lights
Front doors light up the ceiling and door lights
The back doors do nothing but I do have a hi output motion detector for the door with the fridge
I also use a hi output motion detector for my flip up rear windows
The rear hatch only operates the rear hatch with a red - off - white light option on the hatch
Thread revival. I'm looking at adding a separate "dome" light over the front seat and was planning to tap into the drivers door switches so that they will come on with the middle row dome. I'll admit I'm a bit electrically challenged so I made an attempt last night but was not exactly successful. The switch has a power lead and the ground is through the mounting plate and get interrupted or loses ground when the switch button is pressed. I tapped into the power lead with the power lead for the new light but can't figure out how to get the ground to operate correctly. If I ground to the plate like the switch is, the new light comes on when the button is pressed instead of when the botton is released as the door is opened. Basically it's doing the opposite of what I want it to.
Anyone done this or can point an electrical bum in the right direction?
