Does the e-brake cable wear out?
1996 80 series, US model with a 1HDFT.
My e-brake handle is adjusted to the max, the rear shoes are new and adjusted correctly.
Still, I have to pull the handle as much as possible and it barely holds the truck. Do these cables wear out and stretch? Does anyone have experience with that?
A new one is cheap, but will it fix my problem?
thanks, Jan
Curious about this as well. I had a cable replaced on an old 83/84 diesel Corolla I once owned and noticed it grabbed much lower when pulling it once the shop replaced it.
That thing was a beast. I can't BELIEVE we sold it :bang:.
If throttle cables can stretch then an e-brake cable wouldn't be too hard to imagine especially since you crank on it ;)
Did you guys adjust the shoes already?
My handle was really sloppy and the shoes wouldn't hold when I had a seized up brake shoe parts :eek:
Replaced a few needed parts and only had to make a slight adjustment at the handle after that :cool:
Yes, shoes are adjusted and new.
cheers,
jan
If the shoes are new and adjusted properly and the cable is still adjusted to its max, then the cable is stretched and needs to be replaced. That is a :banana: job.
It is very unlikely that the drum portion of a rear disc is worn out. If they are drum brakes, good luck with adjustments, etc. That is one of the reasons I switched to a disc brake axle.
I think I'm in the same boat. Replaced shoes and adjusted. It works so well for awhile it pulled the cable off the shoe. Put back together and it is slowly getting less tension now.
IMO a cable wouldn't be able to stretch that much. If the shoes are adjusted properly, then any possible slack that could develop from a cable stretching could be adjusted at the handle.
Check the shoe adjustment according to the FSM. If you can max out the handle and the shoes don't engage, then the shoes are not set up correctly or there is another issue with the handbrake mechanism inside one of the drums.
^^ What he said ^^
That's a well built cable. I'm sure it's possible, but there's almost 2" of adjustment between the end and in the drums, I don't think it could stretch that much.
I haven't dealt with this cable in particular being a new 80 owner, but I do deal with control cables on a regular basis.
It's not really the cable "stretching", a more accurate description is the outer housing gets shorter. Unless the flexible housing is longitudinally wound (is it?), there will be compression.
You would be surprised how much a cable can stretch through repeated use. The adjustment space left on the end of the cable at the brake lever is mostly to account for tolerance of the length of the cable during its manufacturing. Like everything else, it has a set life and our trucks are old enough to reach that life limit on lots of parts.
If you set your brake every time you park and you DD your truck...
Drive to work, Set the brake.
Drive to lunch, set the brake.
Drive back to work, set the brake.
Drive home, set the brake.
4 cycles per day.
365 days per year. (consider running errands on the weekends similar to a normal work day)
20 years.
29,200 cycles + driving to dinner
Also consider the lever arm used to set the brake and release it.
You might be only pulling with 20lbs of force, but it gets multiplied by the lever and could easily reach 200 lbs of force in the cable.
Do that ~30k times and it'll likely fatigue.
Surprise me ;)
I'm on the original cable on my 91 with over 260K miles and 25 years of setting the brake every time. I had to take up some slack in the cable a few years ago, but she'll grab hard with 5 clicks and lock the wheels with 6 or 7.
But, I maintain my brakes. On the FF rear you need to periodically adjust the handbrake shoes as there is no auto adjuster like there is on a SF rear.
There are cables inside the drum that get pulled on by the bell cranks and they have to be seated correctly in the pivot or they won't work.
If you're pulling the handle to max and there is no contact, then something is wrong mechanically that can't be attributed to a stretched cable. Cables don't stretch that much.
4 cycles per day.
20 years.
Nice breakdown. I never really thought to much about the parking brake until I went to a manual trans. Now it MUST work in order to get out of the truck with trans in neutral and engine running. I adjusted the lever today. Feels good but time will tell.
I need to adjust mine but it appears as this is different than any other PB I've ever dealt with. PB pads are good w/new rotors. Takes 12+ clicks before mine will lock the tires solid on a ~25* driveway. Do I start w/the handle adjustment? I have no idea how to do it inside the rotor/axle end of it.
