Does OME Heavy+Arb/Winch = Front Spacer?
Indianapolis
Here are some questions that I have post lift. I have installed an OME heavy suspension and the rear end sticks up pretty high.
If I add an ARB and winch, will I need to add spacers up front to level things out?
If so, what size spacer is best?
If I do add spacers, how will things look after sliders and rear bumper are added? Will the spacers need to come out when weight is added to the rear?
If I need to raise the front end, would it be better to use a different spring such as a J spring?
For those of you who have installed the heavy, what are your experiences when adding these accessories? Couldn't find an already definitive thread on this issue.
Thanks.
either way I have 1 inch spacers on my front and it sits pretty level. I would think J's with the ARB and winch would be the ticket. I checked out the registry to see what setups looked like before I decided on mine.
Pretty happy with the 850J's in front
94 FZJ80 with rear end high
I just picked up my first FZJ80 (1994). It has an OME with an ARB up front. The rear end sits way higher. I'm wondering how to correct myself. Not hijacking your thread just adding to it!
I added a 1 inch poly spacer from Slee to level it a bit.
It's a fairly cheap and easy to install mod, and it would only take an hour or two to decide if you like it.
I have the heavy up front with spacer and heavy rear, with my arb it pulls it down a little, but it is not level by any means. I have given thought to getting the J springs to bring it back to level.
Do you also have a winch? I got my ARB and Warn XD9000 winch installed on Sunday and I was surprised that the bumper/winch only brought the front end down by .5 of an inch. I don't want level when all is said and done in case I need to carry a bunch of weight in the back. I also believe adding sliders will bring the rear down by some as well not to mention a rear bumper set up which will come much later. It sits pretty high in the rear now though but I can live with it until the sliders are installed. Will try to get some pics posted soon. Thanks for posting. Anyone else?
Just measured the front and rear...ground to flare.
Front = 37.25 inches
Rear = 39.5 inches
Does anyone know how much adding sliders will lower the rear relative to the front or would it be an equal lowering front/rear?
Yeah I have a xd9000 winch, no sliders but my springs are 4 years old so may be due for a replacement but I wouldnt think so.
On my stock springs putting the sliders on didn't really bring one end down more than the other. I didn't take measurements, but it looked no different before and after. They pretty well span the area between the wheels, so I figure they add equal weight to each end.
My $.02
Sliders bring both ends down equally. A rear bumper could bring down your rear end alot, but probably not enough to get the stinkbug look in check.
You've got a 2.25" difference between the front and rear....I'd buy a pair of Metal Tech 1.5" spacers and call it done.
Rear = 39.5 inches
I would be looking to a different spring manufacturer if I bought a lift that had a 2.25" variance in height between front and rear, not rewarding them with more business :rolleyes:
I went with 850J's in front and still had to use a 1" spacer to level out with the 863's in the rear. I have an ARB/ Warn M12000 and sliders. Scroll through my threads and you can see pics of mine pre and post-lift. I also have measurements in the thread.
TK
So when you use a OME heavy suspension with no load on the truck and it sits raked, that is the spring manufacturers issue? How about using the correct spring for the correct application. It is really weird that when we install the suspensions in the shop and use the correct application we do not have this issue. We have acceptable rake on a truck that is expected to carry additional weight when loaded.
From what I understand the FOR gen II lift will still result in a rake with ARB and Winch installed, I know someone who has one and had to get frankie to cut the springs in the rear to level it out. I am not a fan of cutting springs, but I guess whatever your pleasure. But I do have the heavy application up front, and one of christo's poly spacers, and mine is still at a slight rake.
Sidebar; Christo, do you think if I did J springs in the front with ARB and XD9000 winch i'd be more level than with the current setup?
Thanks.
1. If you add ARB and winch on your 850, you will need to add 1 inch poly spacers on top or get the 850J and add 20mm OME poly spacers to somewhat level it out.
2. If you add sliders and rear bumper, might as well get the 4" Slee lift kit because the sliders will definitely will make the truck heavy.
Here's a picture of my truck with 850J/N73L shocks, ARB bumper with XD9000, dual batteries and the rear has 863/N74E shocks with Kaymar Deluxe bumper with tire carrier and still has the stinkbug. I need to add 10 to 15 mm OME poly spacer on the driver side front spring. Right now, I only have 5mm poly spacer up there. The driver side is about 1/4" low compare to the Passenger side.
I wish I had these kind of problems, that would mean I have a lift.
I hate the stinkbug style .. so I run a J and front MAF spacers to make she looks leveled .. and a bit higger in front ..
main.php
main.php
