I received my pair of RCV Performance cv shafts last week and finally had time to try to swap one into the SpressoWagon this afternoon. No instructions whatsoever were included and no response after repeated calls and messages to RCV. My only real question up until today's install issue was the bolt torque that should be applied to the 6-allen type bolts that retain the inner cup and spline assembly (they ship them so that you have to bolt the end cap spline assembly to the CV shaft assembly); and whether I should use Loctite due to no included washers, flat or otherwise, under the bolt heads. For the record I lightly 242'd them and tightened them to about 70ft lbs.
But the install is not going so smoothly. The RCV shaft acts like it is too short as it stops short about 1" from seating into the needle bearing and extending past the hub flange for circlip engagement. Its been a day so I just decided to start up again on the process tomorrow morning when I'm fresh.
Although they certainly look robust I'm a little disappointed RCV did not adhere to the similar outer double seal found on the OEM Toyota shafts. Maybe incidental but OTOH the OEM redundant seals really do work well/effectively keeping the needle and hub bearings free of water, dirt and outside contaminants under the harshest of conditions. Maybe a non-issue but...
Or possibly 15-days isn't enough time for Sean to get either promise fulfilled
