Do I..... We Stink?
imyahucklbrry
“In Vino Veritas”
GA - As close to the lake as I can afford...
I’ve had my ‘mistress’..... er 40 for 5 years now - I have attempted to improve her as my abilities and finances are capable of but..... after returning the carburetor to an Aisan, previously a leaky Holley - replacing fuel lines/filters - changed any suspect vacuum lines - distributor cap - plugs/wires etc., etc to eliminate the smell (gas/exhaust)......
After a drive I still get the same comment from my best girl and that LOOK! I don’t notice a dang thing; maybe I’m immune to it or I like the way I smell but I ask:
Do I....... We Stink? 🤥
edit: We = all 40 owners
Hi ...I have the same problem. trying to figure out how far to go tuning and cleaning carb etc... before I just give up!
Remove the top and enjoy the Fall air, well, soon it will be enjoyable! Problem solved...... :hillbilly:
Are you sure it's the carb? When I replaced all the soft lines in my fuel system, from the tank to the carb, as well as addressing the charcoal canister (vents to the rear of my rig now), what a difference that made.
Honestly, I think the wife just has a very ‘sensitive’ nose..... I don’t detect a gas smell anymore - maybe it’s just good ole ‘classic vehicle’ aroma she smells!
It just cracks me up sometimes when I come in and she does the sniff........ made me think of that scene in Top Gun ;)
My wife said my rig smelled like an old man when I purchased it, circa 03/14. Five years have passed, many changes, modifications and upgrades later, now she will actually ask to go for a ride. Especially on Friday nights to the pizza joint, and a couple of Sunday's ago to Caffeine & Octane.
I take it, she likes the 40 now.....or she has lost her sense of smell. :hillbilly:
I acquired my love just a few months after you but dare say I’ve not refined her nearly so well as you! :cheers:
Mine has only smelled like gasoline twice; once when the fuel pump went out and once when one of the soft fuel lines slpit and leaked. Once I fixed those, all it ever smells like is 2F heat. Wife doesn't complain but she's not crazy about having her hair blown all over the place.
The only time the lovely Mrs. skidplate complains of stinkage is after I 'm around gear oil. She always says "you've been using that stinky oil again!"
Mine will smell like gas when I first open the door. Goes away after driving it for a bit. I attribute that because of all of the leaks throughout the cabin. Hotter than Hades in Summer time, colder than the Well Diggers...well you get the idea.
Both our dogs tangled with a skunk recently so the 40 gets a pass. ed
I'll say this, one of my first modifications was to replace all the old fuel lines and filler neck. While working in my basement, and not really thinking about the amount of fuel in my rig since the gauge showed almost empty, I proceeded to I drain the tank. Note, doing this step in your basement, may not be the best thing! At least I was fortunate enough to have run the tank near empty. So with only a few gallons in there, I proceed to remove the supply line at the frame and drain, but I put about half a gallon on the basement floor. Time to open the door and out comes the fan! Not to mention questions being yelled from above, "WHAT IS THAT GAS SMELL?!?!?!?!"....Yes, I know I should have taken out the drain plug.
Is it just gasoline smell and/or exhaust fumes ? I was smelling exhaust in the cab and finally figured it out. My tail pipe was incorrect. Stock has it exhausting 90 degrees from the rear. Mine was straight. Got OEM and no more smell.
I keep trying to tell Mrs Mark’s Off Road that gear oil is just like a thousand cloves of garlic.
She’s full-blooded Italian: she’s not buying it.
There is a particular aroma from my 40's exhaust, smells like old car exhaust. Once in a while I get the gas smell but not so often. It is simply old truck/car exhaust smell and I enjoy it.
