Hi All -
While I've got the front end apart, I wanted to check the angles as I've had some death wobble and didn't know whether to attribute it to the bearings, tie rod ends or caster. Since I'm replacing all the bearings (which for sure didn't have enough preload), tie rod ends, etc. I figured I'd eliminate all the variables (realizing I'd still need to balance tires).
I took some measurements while the front of the truck was up on jack stands so these angles are skewed because of it. Bottom line (based on my interpretation of the angle pics below) my caster angle is 1 degree less than my pinion angle... doesn't that mean I have positive (therefore bad) caster?
FYI - My truck is shackle reversed but has brackets that drop the front of the leaf springs down quite a bit.
Here's what I saw when I measured:
Angle of knuckle as measured through bearing races:
Pinion angle as measured on the flange:
As measured sitting on top of the bearing race:
