I'm having some charging issues on my '91 80. I have a reman. alternator with somewhere around 5,000 miles on it. At idle it puts out 11.5 to 12 volts. When rpms go up to 1500 or so it puts out 14 to 14.5. Now that it's cold out when I let the truck idle to warm up it kills the battery (which is 6 months old & tests good). I recently put in a 650 watt amp that pushes 2- 4", 2-6.5", and 2- 6"x9" speakers. The local alternator rebuild shop run by an old man told me that my amp is drawing to much power and is frying my alternator. He claims that they only way to fix it is rebuild the alt. & get rid of the amp. My questions are: Is a stock alt. enough to run a 650 watt amp? Why would my alt only put out 11.5 at idle but still charge up to 14.5 at higher rpm's?
Thanks for any help you can give.
